Antw.: [Mapbender-users] Problem with SRS EPSG:4189
Arnulf Christl
seven at arnulf.us
Tue Aug 16 17:51:22 EDT 2011
Valenty,
can you send the URL to the Capabilities document, or if it is local just the XML file. And what MB version are you running?
Best regards,
Arnulf
Seven (aka Arnulf)
http://arnulf.us
----- Reply message -----
Von: "Valenty Gonzalez" <gvalenty at gmail.com>
An: <mapbender_users at lists.osgeo.org>
Betreff: [Mapbender-users] Problem with SRS EPSG:4189
Datum: Di., Aug. 16, 2011 23:15
I need to offer a Geoportal with SRS EPSG:4189
The SRS EPSG: 4189 corresponds to the projection REGVEN,for the Republic
of Venezuela.
Problem is, that I build a WMS from Geoserver with that projection
(4189) and when I go to Mapbender by linking the WMS to a GUI always
reads as SRS EPSG: 4326
This situation succes even if i don'tdeclare 4326 in the configuration
of WMS.
So, when i go to the GUI_settings, this option not give me an
opportunity to select EPSG: 4189 and SRS for the portal service. Only
offer 4326 (by default?)
Any ideas?
Thanks in advance,
Valenty Gonzalez
CREATIVA
Venezuela
Asociación gvSIG
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20110816/90387fd9/attachment.html
More information about the Mapbender_users
