[Mapbender-users] Problem with SRS EPSG:4189
Valenty Gonzalez gvalenty at gmail.com
Thu Aug 18 06:33:22 EDT 2011
Arnulf, thank you very much.
I understand perfectly.
But i need on more help (something basic :-) ); i have edited manually
Capabilities doc, but: how can i import this new capabilities (edited)
to mapbender?
What have i to put on "Link to WMS Capabilities URL:"
Thanks again,
Valenty Gonzalez
El 18/08/2011 05:26 a.m., Seven (aka Arnulf) escribió:
> Valenty,
> in the capabilities document the bounding boxes for the corresponding
> SRS are missing. The only one given is for 4326, which is why this is
> the only one Mapbender will accept.
> <SRS>EPSG:2201</SRS>
> <SRS>EPSG:2202</SRS>
> <SRS>EPSG:2203</SRS>
> <SRS>EPSG:32618</SRS>
> <SRS>EPSG:32619</SRS>
> <SRS>EPSG:32620</SRS>
> <SRS>EPSG:4189</SRS>
> <SRS>EPSG:900913</SRS>
> <LatLonBoundingBox minx="-73.38" miny="0.644" maxx="-58.177"
> maxy="12.198"/>
> To this block wou will need to add the fo0llowing:
> <BoundingBox SRS="EPSG:4189" minx="x lower left" miny="y lower left"
> maxx="x upper right" maxy="y upper right"/>
> and replace "x lower left", "y lower left" and so on with the correct
> coordinates of your country.
> Explanation: In order to be able to start the application with your SRS
> you will need to give Mapbender the initial coordinates, otherwise it
> will not know where to draw the maps.
> Later versions of Mapbender have an additional feature that will
> calculate bounding boxes for all SRS given in the capabilities on its
> own. Mapbender uses PostGIS to calculate the bounding boxes, so it needs
> to be activated and working correctly.
> If you cannot convince GeoServer to add the corresponding section as a
> workaround you can store the Capabilities doc as a file and edit it
> manually. Remember that every time you change anything in the
> capabilities you will have to manually add the coordinates again.
> Just a side note: In the current set up you have the "estados" layer
> right on top of all the other ones. I would suggest to turn this around
> and draw the "estados" as the base layer (listed first in the
> capabilities wiht ID=0), then the others will be displayed on top
> automatically.
> Hope this helps.
> Best regards,
> Arnulf
> On 17.08.2011 00:25, Valenty Gonzalez wrote:
> > Arnulf,
> > I'm using MB version 2.6.2 on Debian Squeeze (Linux desarrollo
> > 2.6.26-2-686). Sorry for not include this information before :-S
> > URL to Capabilities:
> http://200.75.140.108:8080/geoserver/wms?service=WMS&version=1.1.0&request=GetCapabilities
> > Regards,
> > Valenty
> > El 16/08/2011 05:21 p.m., Arnulf Christl escribió:
> >> Valenty,
> >> can you send the URL to the Capabilities document, or if it is local
> >> just the XML file. And what MB version are you running?
> >> Best regards,
> >> Arnulf
> >> Seven (aka Arnulf)
> >> http://arnulf.us
> >> ----- Reply message -----
> >> Von: "Valenty Gonzalez" <gvalenty at gmail.com>
> >> An: <mapbender_users at lists.osgeo.org>
> >> Betreff: [Mapbender-users] Problem with SRS EPSG:4189
> >> Datum: Di., Aug. 16, 2011 23:15
> >> Hi,
> >> I need to offer a Geoportal with SRS EPSG:4189
> >> The SRS EPSG: 4189 corresponds to the projection REGVEN,for the
> Republic
> >> of Venezuela.
> >> Problem is, that I build a WMS from Geoserver with that projection
> >> (4189) and when I go to Mapbender by linking the WMS to a GUI always
> >> reads as SRS EPSG: 4326
> >> This situation succes even if i don'tdeclare 4326 in the configuration
> >> of WMS.
> >> So, when i go to the GUI_settings, this option not give me an
> >> opportunity to select EPSG: 4189 and SRS for the portal service. Only
> >> offer 4326 (by default?)
> >> Any ideas?
> >> Thanks in advance,
> >> Valenty Gonzalez
> >> CREATIVA
> >> Venezuela
> >> Asociación gvSIG
> >> _______________________________________________
> >> Mapbender_users mailing list
> >> Mapbender_users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
