[Mapbender-users] Problem with SRS EPSG:4189
Valenty Gonzalez gvalenty at gmail.com
Thu Aug 18 12:58:39 EDT 2011
Hello Armin, Arnulf
I have solved my problem. The Geoportal now it is running on EPSG:4189
(rigth to the law, jeje)
Thank so much, you really really help me.
Regards from Venezuela,
Valenty
El 18/08/2011 06:18 a.m., Armin Retterath escribió:
> hello valenty,
> you simply can upload local files by writing:"file://{pathToFile}" in the
> textfield for upload capabilities. example: "file:///tmp/capabilities.xml"
> regards
> armin
> Am Donnerstag, 18. August 2011 12:38:11 schrieb Valenty Gonzalez:
>> Thanks Armin,
>> It's a good notice. I will use for a future geoportal with mapbender-2.7.x
>> Now, I will practice already in my practice enviroment
>> Regards,
>> El 18/08/2011 05:58 a.m., Armin Retterath escribió:
>>> hello,
>>> in the mapbender.conf file there is a constant which can be set to the
>>> srs which should be handled by the mapbender installation. please
>>> uncomment it an fill in your srs. for the srs which are supported by your
>>> wms and which have no bboxes defined in the capabilities doc new bboxes
>>> will be calculated by postgis as arnulf claimed before.
>>> the function maybe new and it will only work in mapbender 2.7.x - as far
>>> as i know.
>>> best regards
>>> armin
>>> line from mapbender.conf:
>>> #define("SRS_ARRAY", "4326,31466,31467,31468,25832");
>>> Am Donnerstag, 18. August 2011 11:56:31 schrieb Seven (aka Arnulf):
>>>> Valenty,
>>>> in the capabilities document the bounding boxes for the corresponding
>>>> SRS are missing. The only one given is for 4326, which is why this is
>>>> the only one Mapbender will accept.
>>>> <SRS>EPSG:2201</SRS>
>>>> <SRS>EPSG:2202</SRS>
>>>> <SRS>EPSG:2203</SRS>
>>>> <SRS>EPSG:32618</SRS>
>>>> <SRS>EPSG:32619</SRS>
>>>> <SRS>EPSG:32620</SRS>
>>>> <SRS>EPSG:4189</SRS>
>>>> <SRS>EPSG:900913</SRS>
>>>> <LatLonBoundingBox minx="-73.38" miny="0.644" maxx="-58.177"
>>>>  maxy="12.198"/>
>>>> To this block wou will need to add the fo0llowing:
>>>> <BoundingBox SRS="EPSG:4189" minx="x lower left" miny="y lower left"
>>>> maxx="x upper right" maxy="y upper right"/>
>>>> and replace "x lower left", "y lower left" and so on with the correct
>>>> coordinates of your country.
>>>> Explanation: In order to be able to start the application with your SRS
>>>> you will need to give Mapbender the initial coordinates, otherwise it
>>>> will not know where to draw the maps.
>>>> Later versions of Mapbender have an additional feature that will
>>>> calculate bounding boxes for all SRS given in the capabilities on its
>>>> own. Mapbender uses PostGIS to calculate the bounding boxes, so it needs
>>>> to be activated and working correctly.
>>>> If you cannot convince GeoServer to add the corresponding section as a
>>>> workaround you can store the Capabilities doc as a file and edit it
>>>> manually. Remember that every time you change anything in the
>>>> capabilities you will have to manually add the coordinates again.
>>>> Just a side note: In the current set up you have the "estados" layer
>>>> right on top of all the other ones. I would suggest to turn this around
>>>> and draw the "estados" as the base layer (listed first in the
>>>> capabilities wiht ID=0), then the others will be displayed on top
>>>> automatically.
>>>> Hope this helps.
>>>> Best regards,
>>>> Arnulf
>>>> On 17.08.2011 00:25, Valenty Gonzalez wrote:
>>>>> Arnulf,
>>>>> I'm using MB version 2.6.2 on Debian Squeeze (Linux desarrollo
>>>>> 2.6.26-2-686). Sorry for not include this information before :-S
>>>>> URL to Capabilities:
>>>>> http://200.75.140.108:8080/geoserver/wms?service=WMS&version=1.1.0&requ
>>>>> es t=GetCapabilities
>>>>> Regards,
>>>>> Valenty
>>>>> El 16/08/2011 05:21 p.m., Arnulf Christl escribió:
>>>>>> Valenty,
>>>>>> can you send the URL to the Capabilities document, or if it is local
>>>>>> just the XML file. And what MB version are you running?
>>>>>> Best regards,
>>>>>> Arnulf
>>>>>> ----- Reply message -----
>>>>>> Von: "Valenty Gonzalez" <gvalenty at gmail.com>
>>>>>> An: <mapbender_users at lists.osgeo.org>
>>>>>> Betreff: [Mapbender-users] Problem with SRS EPSG:4189
>>>>>> Datum: Di., Aug. 16, 2011 23:15
>>>>>> Hi,
>>>>>> I need to offer a Geoportal with SRS EPSG:4189
>>>>>> The SRS EPSG: 4189 corresponds to the projection REGVEN,for the
>>>>>> Republic of Venezuela.
>>>>>> Problem is, that I build a WMS from Geoserver with that projection
>>>>>> (4189) and when I go to Mapbender by linking the WMS to a GUI always
>>>>>> reads as SRS EPSG: 4326
>>>>>> This situation succes even if i don'tdeclare 4326 in the configuration
>>>>>> of WMS.
>>>>>> So, when i go to the GUI_settings, this option not give me an
>>>>>> opportunity to select EPSG: 4189 and SRS for the portal service. Only
>>>>>> offer 4326 (by default?)
>>>>>> Any ideas?
>>>>>> Thanks in advance,
>>>>>> Valenty Gonzalez
>>>>>> CREATIVA
>>>>>> Venezuela
>>>>>> Asociación gvSIG
>>>>>> _______________________________________________
>>>>>> Mapbender_users mailing list
>>>>>> Mapbender_users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
