[Mapbender-users] Problem with SRS EPSG:4189
Armin Retterath
armin.retterath at lvermgeo.rlp.de
Thu Aug 18 06:48:33 EDT 2011
hello valenty,
you simply can upload local files by writing:"file://{pathToFile}" in the
textfield for upload capabilities. example: "file:///tmp/capabilities.xml"
regards
armin
Am Donnerstag, 18. August 2011 12:38:11 schrieb Valenty Gonzalez:
> Thanks Armin,
> It's a good notice. I will use for a future geoportal with mapbender-2.7.x
> Now, I will practice already in my practice enviroment
> Regards,
> El 18/08/2011 05:58 a.m., Armin Retterath escribió:
> > hello,
> > in the mapbender.conf file there is a constant which can be set to the
> > srs which should be handled by the mapbender installation. please
> > uncomment it an fill in your srs. for the srs which are supported by your
> > wms and which have no bboxes defined in the capabilities doc new bboxes
> > will be calculated by postgis as arnulf claimed before.
> > the function maybe new and it will only work in mapbender 2.7.x - as far
> > as i know.
> > best regards
> > armin
> > line from mapbender.conf:
> > #define("SRS_ARRAY", "4326,31466,31467,31468,25832");
> > Am Donnerstag, 18. August 2011 11:56:31 schrieb Seven (aka Arnulf):
> >> Valenty,
> >> in the capabilities document the bounding boxes for the corresponding
> >> SRS are missing. The only one given is for 4326, which is why this is
> >> the only one Mapbender will accept.
> >> <SRS>EPSG:2201</SRS>
> >> <SRS>EPSG:2202</SRS>
> >> <SRS>EPSG:2203</SRS>
> >> <SRS>EPSG:32618</SRS>
> >> <SRS>EPSG:32619</SRS>
> >> <SRS>EPSG:32620</SRS>
> >> <SRS>EPSG:4189</SRS>
> >> <SRS>EPSG:900913</SRS>
> >> <LatLonBoundingBox minx="-73.38" miny="0.644" maxx="-58.177"
> >> maxy="12.198"/>
> >> To this block wou will need to add the fo0llowing:
> >> <BoundingBox SRS="EPSG:4189" minx="x lower left" miny="y lower left"
> >> maxx="x upper right" maxy="y upper right"/>
> >> and replace "x lower left", "y lower left" and so on with the correct
> >> coordinates of your country.
> >> Explanation: In order to be able to start the application with your SRS
> >> you will need to give Mapbender the initial coordinates, otherwise it
> >> will not know where to draw the maps.
> >> Later versions of Mapbender have an additional feature that will
> >> calculate bounding boxes for all SRS given in the capabilities on its
> >> own. Mapbender uses PostGIS to calculate the bounding boxes, so it needs
> >> to be activated and working correctly.
> >> If you cannot convince GeoServer to add the corresponding section as a
> >> workaround you can store the Capabilities doc as a file and edit it
> >> manually. Remember that every time you change anything in the
> >> capabilities you will have to manually add the coordinates again.
> >> Just a side note: In the current set up you have the "estados" layer
> >> right on top of all the other ones. I would suggest to turn this around
> >> and draw the "estados" as the base layer (listed first in the
> >> capabilities wiht ID=0), then the others will be displayed on top
> >> automatically.
> >> Hope this helps.
> >> Best regards,
> >> Arnulf
> >> On 17.08.2011 00:25, Valenty Gonzalez wrote:
> >>> Arnulf,
> >>> I'm using MB version 2.6.2 on Debian Squeeze (Linux desarrollo
> >>> 2.6.26-2-686). Sorry for not include this information before :-S
> >>> URL to Capabilities:
> >>> http://200.75.140.108:8080/geoserver/wms?service=WMS&version=1.1.0&requ
> >>>es t=GetCapabilities
> >>> Regards,
> >>> Valenty
> >>> El 16/08/2011 05:21 p.m., Arnulf Christl escribió:
> >>>> Valenty,
> >>>> can you send the URL to the Capabilities document, or if it is local
> >>>> just the XML file. And what MB version are you running?
> >>>> Best regards,
> >>>> Arnulf
> >>>> ----- Reply message -----
> >>>> Von: "Valenty Gonzalez" <gvalenty at gmail.com>
> >>>> An: <mapbender_users at lists.osgeo.org>
> >>>> Betreff: [Mapbender-users] Problem with SRS EPSG:4189
> >>>> Datum: Di., Aug. 16, 2011 23:15
> >>>> Hi,
> >>>> I need to offer a Geoportal with SRS EPSG:4189
> >>>> The SRS EPSG: 4189 corresponds to the projection REGVEN,for the
> >>>> Republic of Venezuela.
> >>>> Problem is, that I build a WMS from Geoserver with that projection
> >>>> (4189) and when I go to Mapbender by linking the WMS to a GUI always
> >>>> reads as SRS EPSG: 4326
> >>>> This situation succes even if i don'tdeclare 4326 in the configuration
> >>>> of WMS.
> >>>> So, when i go to the GUI_settings, this option not give me an
> >>>> opportunity to select EPSG: 4189 and SRS for the portal service. Only
> >>>> offer 4326 (by default?)
> >>>> Any ideas?
> >>>> Thanks in advance,
> >>>> Valenty Gonzalez
> >>>> CREATIVA
> >>>> Venezuela
> >>>> Asociación gvSIG
> >>>> _______________________________________________
> >>>> Mapbender_users mailing list
> >>>> Mapbender_users at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Armin Retterath
Zentrale Stelle GDI-RP
LVermGeo RHEINLAND-PFALZ
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261 492-466
Telefax 0261 492-492
www.geoportal.rlp.de
More information about the Mapbender_users
