[Mapbender-users] Print pdf: rotate don't work
zorg
zorg at probesys.com
Thu Dec 1 03:54:14 EST 2011
Hi Astrid,
Thanks.
Imagick is installed but I have an php error with Imagik (only for
rotation):
PHP Fatal error: Uncaught exception 'ImagickException' with message
'Can not use empty string as a filename' in
/home/mapbender/http/classes/class_weldMaps2PNG_rotate.php:78...
I try to find the error.
The good link: http://www.mapbender.org/index.php/Demo
you can test the "print demo"
Zorg
Le 30/11/2011 13:28, Astrid Emde a écrit :
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi zork,
> did you install php5-imagick ?
> The link to your demo does not work. Please send a user and password to
> login.
> Have a look at your php and apache logs.
> Astrid
> zorg schrieb:
>> Hi,
>> I use print_pdf with template (Mapbender 2.7.2). It's work with the
>> scale and my personnal template but when I use rotation, I have an error.
>> The demo work :
>> http://projects.mapbender.osgeo.org/trunk/frames/index.php?PHPSESSID=018d34f1695292420643c2a68acc9217&gui_id=template_print&mb_user_myGui=template_print
>> Have you got an idea?
>> Thanks for your help.
>> zorg
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> Where2B Konferenz 2011
> 01. Dezember 2011 in Bonn
> http://www.where2b-conference.com
> Aufwind durch Wissen!
> Qualifizierte OpenSource-Schulungen
> bei der www.foss-academy.eu
> Astrid Emde
> WhereGroup GmbH& Co.KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 19
> Fax: +49(0)228 90 90 38 - 11
> astrid.emde at wheregroup.com
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> pgp-public key:
> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Signed and/or encrypted mail is highly appreciated
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAk7WIXUACgkQBtpS1y1RUoRjQQCeMEKyW4w+q5q1YBiM9BlC/+CO
> XEIAnRYb2iBPdlS1B/coT/nsP4jBtUus
> =7nJg
> -----END PGP SIGNATURE-----
More information about the Mapbender_users
