[Mapbender-users] Print pdf: rotate don't work
zorg
zorg at probesys.com
Thu Dec 1 04:54:27 EST 2011
It's work.
You need to correct in http/classes/class_weldMaps2PNG_rotate.php:78
Before: $imagick->writeImage();
Correction : $imagick->writeImage($filename);
zorg
Le 01/12/2011 09:54, zorg a écrit :
> Hi Astrid,
> Thanks.
> Imagick is installed but I have an php error with Imagik (only for
> rotation):
> PHP Fatal error: Uncaught exception 'ImagickException' with message
> 'Can not use empty string as a filename' in
> /home/mapbender/http/classes/class_weldMaps2PNG_rotate.php:78...
> I try to find the error.
> The good link: http://www.mapbender.org/index.php/Demo
> you can test the "print demo"
> Zorg
> Le 30/11/2011 13:28, Astrid Emde a écrit :
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Hi zork,
>> did you install php5-imagick ?
>> The link to your demo does not work. Please send a user and password to
>> login.
>> Have a look at your php and apache logs.
>> Astrid
>> zorg schrieb:
>>> Hi,
>>> I use print_pdf with template (Mapbender 2.7.2). It's work with the
>>> scale and my personnal template but when I use rotation, I have an
>>> error.
>>> The demo work :
>>> http://projects.mapbender.osgeo.org/trunk/frames/index.php?PHPSESSID=018d34f1695292420643c2a68acc9217&gui_id=template_print&mb_user_myGui=template_print
>>> Have you got an idea?
>>> Thanks for your help.
>>> zorg
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Mit freundlichen Grüßen
>> Astrid Emde
>> Where2B Konferenz 2011
>> 01. Dezember 2011 in Bonn
>> http://www.where2b-conference.com
>> Aufwind durch Wissen!
>> Qualifizierte OpenSource-Schulungen
>> bei der www.foss-academy.eu
>> Astrid Emde
>> WhereGroup GmbH& Co.KG
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Fon: +49(0)228 90 90 38 - 19
>> Fax: +49(0)228 90 90 38 - 11
>> astrid.emde at wheregroup.com
>> www.wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
>> pgp-public key:
>> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>> Signed and/or encrypted mail is highly appreciated
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.9 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
>> iEYEARECAAYFAk7WIXUACgkQBtpS1y1RUoRjQQCeMEKyW4w+q5q1YBiM9BlC/+CO
>> XEIAnRYb2iBPdlS1B/coT/nsP4jBtUus
>> =7nJg
>> -----END PGP SIGNATURE-----
More information about the Mapbender_users
