[Mapbender-users] Installation problem "Compiling .po files..."
martina ikert
martinaikert at hotmail.com
Thu Dec 1 14:16:43 EST 2011
Good evening,
it't very interesting to read that there are users getting an answer. I had a question in June or Juli and never got any answer and had to quit the project. (problems with uploading the capabilities) Shall I try again?
Greetings
Martina
> Date: Wed, 30 Nov 2011 13:34:22 +0100
> From: astrid.emde at wheregroup.com
> To: mapbender_users at lists.osgeo.org
> Subject: Re: [Mapbender-users] Installation problem "Compiling .po files..."
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hello,
> at the moment we only provide an i18n_update_mo.sh at mapbender/tools.
> The script install.bat copies i18n_update_mo.sh to i18n_update_mo.bat
> and runs the bat.
> Try to create the file i18n_update_mo.bat by hand and run it. This
> should create the Mapbender mo-files.
> Best regards Astrid
> dstroeer at uni-osnabrueck.de schrieb:
> > Hello everybody,
> > I've got a problem with the installation of mapbender. You can find the
> > error message below...
> > I'm using windows 7 and mapbender 2.7.2 and allready tried it with
> > mapbender 2.6.2. PostgreSQL and Poedit are allready installed, too.
> > So first of all a asked a friend, who also uses mapbender 2.6.2 and
> > windows 7. His application is running fine, but when he tried to run the
> > install.bat for windows again, he got the same message! So we are at a
> > loss...
> > Thanking you in anticipation,
> > Dennis
> > DISCLAIMER: Mapbender database setup script. USE AT YOUR OWN RISK!
> > This script will create a database for you and will import the Mapbender
> > data to
> > the new database
> > It will possibly also compile the Mapbender.mo files
> > You need:
> > - a running postgresql 8.x database
> > - database user with write access
> > If everything is prepared you can continue.
> > You can give nearly all arguments on commandline:
> > "C:\ms4w\Apache\htdocs\mapbender\resources\db\install.bat <HOST> <PORT>
> > <DBNAME>
> > <DBTEMPLATE> <DBUSER>"
> > e.g.
> > C:\ms4w\Apache\htdocs\mapbender\resources\db\install.bat localhost 5432
> > mapbende
> > r template0 postgres
> > Continue?
> > (y)es or (n)o:y
> > Database host (just hit return for default 'localhost'):
> > Database port (just hit return for default '5432'):
> > Database name:mapbender
> > database template to use (just hit return for default 'template0'):
> > Database user:postgres
> > Database Password will be asked many times during install, unless
> > pgpass.conf is
> > used...
> > Your Choices:
> > Databasetype: PostgreSQL
> > Encoding: UTF-8
> > Database Host: localhost
> > Database Port: 5432
> > Database Name: mapbender
> > Database Template: template0
> > Database User: postgres
> > Looks ok, start install?
> > (y)es or (n)o? y
> > creating db
> > creating schema
> > importing data
> > setting sequences
> > performing updates
> > update to 2.5.1rc1
> > update to 2.5.1
> > update to 2.6rc1
> > update to 2.6
> > update to 2.6.1
> > update to 2.6.2
> > update to 2.7rc1
> > update to 2.7rc2 to 2.7.1
> > update to 2.7.2
> > update sequences
> > Das System kann den angegebenen Pfad nicht finden.
> > please check and edit your mapbender.conf.
> > FINDSTR: i18n_update_mo.sh kann nicht geöffnet werden.
> > Finished...check the log files to see if an error occured.
> > Drücken Sie eine beliebige Taste . . .
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> Where2B Konferenz 2011
> 01. Dezember 2011 in Bonn
> http://www.where2b-conference.com
> Aufwind durch Wissen!
> Qualifizierte OpenSource-Schulungen
> bei der www.foss-academy.eu
> Astrid Emde
> WhereGroup GmbH & Co.KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 19
> Fax: +49(0)228 90 90 38 - 11
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> pgp-public key:
> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Signed and/or encrypted mail is highly appreciated
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAk7WIs4ACgkQBtpS1y1RUoQgfgCePSTuaY4exR0zaMLs96MIej23
> 8FoAoKBTH6z5slBLLbdkdwgXy02lbCLx
> =oeij
> -----END PGP SIGNATURE-----
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20111201/b50d22c8/attachment.html
More information about the Mapbender_users
