****SPAM Mail****RE: [Mapbender-users] Installation problem
"Compiling .po files..."
Armin Retterath
armin.retterath at lvermgeo.rlp.de
Fri Dec 2 05:16:58 EST 2011
yes - please try again :-)
Am Donnerstag, den 01.12.2011, 19:16 +0000 schrieb martina ikert:
> Good evening,
> it't very interesting to read that there are users getting an answer.
> I had a question in June or Juli and never got any answer and had to
> quit the project. (problems with uploading the capabilities) Shall I
> try again?
> Greetings
> Martina
> ______________________________________________________________________
> > Date: Wed, 30 Nov 2011 13:34:22 +0100
> > From: astrid.emde at wheregroup.com
> > To: mapbender_users at lists.osgeo.org
> > Subject: Re: [Mapbender-users] Installation problem "Compiling .po
> files..."
> > -----BEGIN PGP SIGNED MESSAGE-----
> > Hash: SHA1
> > Hello,
> > at the moment we only provide an i18n_update_mo.sh at
> mapbender/tools.
> > The script install.bat copies i18n_update_mo.sh to
> i18n_update_mo.bat
> > and runs the bat.
> > Try to create the file i18n_update_mo.bat by hand and run it. This
> > should create the Mapbender mo-files.
> > Best regards Astrid
> > dstroeer at uni-osnabrueck.de schrieb:
> > > Hello everybody,
> > > I've got a problem with the installation of mapbender. You can
> find the
> > > error message below...
> > > I'm using windows 7 and mapbender 2.7.2 and allready tried it with
> > > mapbender 2.6.2. PostgreSQL and Poedit are allready installed,
> too.
> > > So first of all a asked a friend, who also uses mapbender 2.6.2
> and
> > > windows 7. His application is running fine, but when he tried to
> run the
> > > install.bat for windows again, he got the same message! So we are
> at a
> > > loss...
> > > Thanking you in anticipation,
> > > Dennis
> > > DISCLAIMER: Mapbender database setup script. USE AT YOUR OWN RISK!
> > > This script will create a database for you and will import the
> Mapbender
> > > data to
> > > the new database
> > > It will possibly also compile the Mapbender.mo files
> > > You need:
> > > - a running postgresql 8.x database
> > > - database user with write access
> > > If everything is prepared you can continue.
> > > You can give nearly all arguments on commandline:
> > > "C:\ms4w\Apache\htdocs\mapbender\resources\db\install.bat <HOST>
> <PORT>
> > > <DBNAME>
> > > <DBTEMPLATE> <DBUSER>"
> > > e.g.
> > > C:\ms4w\Apache\htdocs\mapbender\resources\db\install.bat localhost
> 5432
> > > mapbende
> > > r template0 postgres
> > > Continue?
> > > (y)es or (n)o:y
> > > Database host (just hit return for default 'localhost'):
> > > Database port (just hit return for default '5432'):
> > > Database name:mapbender
> > > database template to use (just hit return for default
> 'template0'):
> > > Database user:postgres
> > > Database Password will be asked many times during install, unless
> > > pgpass.conf is
> > > used...
> > > Your Choices:
> > > Databasetype: PostgreSQL
> > > Encoding: UTF-8
> > > Database Host: localhost
> > > Database Port: 5432
> > > Database Name: mapbender
> > > Database Template: template0
> > > Database User: postgres
> > > Looks ok, start install?
> > > (y)es or (n)o? y
> > > creating db
> > > creating schema
> > > importing data
> > > setting sequences
> > > performing updates
> > > update to 2.5.1rc1
> > > update to 2.5.1
> > > update to 2.6rc1
> > > update to 2.6
> > > update to 2.6.1
> > > update to 2.6.2
> > > update to 2.7rc1
> > > update to 2.7rc2 to 2.7.1
> > > update to 2.7.2
> > > update sequences
> > > Das System kann den angegebenen Pfad nicht finden.
> > > please check and edit your mapbender.conf.
> > > FINDSTR: i18n_update_mo.sh kann nicht geöffnet werden.
> > > Finished...check the log files to see if an error occured.
> > > Drücken Sie eine beliebige Taste . . .
> > > Mapbender_users mailing list
> > > Mapbender_users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> > Mit freundlichen Grüßen
> > Astrid Emde
> > Where2B Konferenz 2011
> > 01. Dezember 2011 in Bonn
> > http://www.where2b-conference.com
> > Aufwind durch Wissen!
> > Qualifizierte OpenSource-Schulungen
> > bei der www.foss-academy.eu
> > Astrid Emde
> > WhereGroup GmbH & Co.KG
> > Eifelstraße 7
> > 53119 Bonn
> > Germany
> > Fon: +49(0)228 90 90 38 - 19
> > Fax: +49(0)228 90 90 38 - 11
> > www.wheregroup.com
> > Amtsgericht Bonn, HRA 6788
> > Komplementärin:
> > WhereGroup Verwaltungs GmbH
> > vertreten durch:
> > Olaf Knopp, Peter Stamm
> > pgp-public key:
> > http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
> > Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> > Signed and/or encrypted mail is highly appreciated
> > -----BEGIN PGP SIGNATURE-----
> > Version: GnuPG v1.4.9 (GNU/Linux)
> > Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> > iEYEARECAAYFAk7WIs4ACgkQBtpS1y1RUoQgfgCePSTuaY4exR0zaMLs96MIej23
> > 8FoAoKBTH6z5slBLLbdkdwgXy02lbCLx
> > =oeij
> > -----END PGP SIGNATURE-----
Armin Retterath
Zentrale Stelle Geodateninfrastruktur Rheinland-Pfalz
LVermGeo RP
Ferdinand-Sauerbruchstraße 15
56073 Koblenz
Telefon: +49 (0)261/492-466
E-Mail: armin.retterath at lvermgeo.rlp.de
http://www.geoportal.rlp.de
More information about the Mapbender_users
