[Mapbender-users] screen ‘Search Results’ ( ‘Suchergebnisse’) stays empty
Verena Diewald verena.diewald at wheregroup.com
Thu Dec 8 10:45:27 EST 2011
Hi Thijs,
please try the following:
Activate mapbender log level "notice" in mapbender.conf.
Open your current mapbender logfile in the log directory.
Load your application and try to select a point or polygon with spatial
selection tools.
Copy the GetFeature request xml from the logfile which should be logged
there.
Open the GeoServer demo frontend, select the GetFeature option and put
your copied xml there. Do you get an answer from GeoServer there?
Greetings,
Verena
Am 06.12.2011 16:49, schrieb Boer, Thijs de:
> Hi list members,
> After setting up the digitizing module in MB 2.7.2 and using
> setSpatialExtent, the result screen ‘Search Results’ (
> ‘Suchergebnisse’) stays empty (after double click on a point).
> WFS-T with Geoserver works fine and also adding a point or polygon is
> possible. But altering an existing point or polygon is not possible.
> What can be wrong ?
> I’m grateful for any help !
> Thijs de Boer
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20111208/26102de9/attachment.html
More information about the Mapbender_users mailing list
