RE: [Mapbender-users] screen ‘Search Results’ ( ‘Suchergebnisse’) stays empty
Boer, Thijs de W.M.deBoer at uva.nl
Sun Dec 11 07:18:02 EST 2011
Hallo Verena,
Beneath is the relevant selection (I hope) of the Mapbender log file.
How can I start the GeoServer demo frontend ?
Which part of the log file given beneath shall I past in where ?
2011.12.11, 11:52:56,ERROR:
2011.12.11, 11:52:56,Notice: class_wfs_factory: wfs_owsproxy:
2011.12.11, 11:52:56,Notice: class_wfs_factory.getFeature.url: http://www.kaartopmaat.eu:8181/geoserver/wfs
2011.12.11, 11:52:56,Notice: OWS REQUEST: http://www.kaartopmaat.eu:8181/geoserver/wfs
<wfs:GetFeature service="WFS" version="1.1.0" xmlns:wfs="http://www.opengis.net/wfs" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc"><wfs:Query srsName="EPSG:25833" xmlns:cite="http://www.opengeospatial.net/cite" typeName="cite:geotopemergep25833"><ogc:Filter><Intersects><ogc:PropertyName>cite:the_geom</ogc:PropertyName><gml:Polygon srsName='EPSG:25833'><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>417556,5738047 417566,5738047 417566,5738037 417556,5738037 417556,5738047</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects></ogc:Filter></wfs:Query></wfs:GetFeature>
2011.12.11, 11:52:56,Notice: class_connector: load url: http://www.kaartopmaat.eu:8181/geoserver/wfs
2011.12.11, 11:52:56,Notice: connector: http
2011.12.11, 11:52:56,Notice: connector.http.postData: <?xml version="1.0" encoding="UTF-8"?>
Thank you in advance !
Greetings, Thijs de Boer
Van: mapbender_users-bounces at lists.osgeo.org [mapbender_users-bounces at lists.osgeo.org] namens Verena Diewald [verena.diewald at wheregroup.com]
Verzonden: donderdag 8 december 2011 16:45
Aan: mapbender_users at lists.osgeo.org
Onderwerp: Re: [Mapbender-users] screen ‘Search Results’ ( ‘Suchergebnisse’) stays empty
Hi Thijs,
please try the following:
Activate mapbender log level "notice" in mapbender.conf.
Open your current mapbender logfile in the log directory.
Load your application and try to select a point or polygon with spatial selection tools.
Copy the GetFeature request xml from the logfile which should be logged there.
Open the GeoServer demo frontend, select the GetFeature option and put your copied xml there. Do you get an answer from GeoServer there?
Greetings,
Verena
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20111211/3d461a55/attachment.html
More information about the Mapbender_users mailing list
