[Mapbender-users] 2.7 rc1 problem
Hernan Olivera
lholivera at gmail.com
Wed Jan 19 07:19:52 EST 2011
Hi
I've solved the problem (selinux=disabled) for log files. Now setup is
all green :)
But mapbender does not load apps: Mapbender 2.7 rc1...loading
application 'gui1'
Where to look now?
2011/1/18 Hernan Olivera <lholivera at gmail.com>:
> 2011/1/18 Thomas Baschetti <info at thomas-baschetti.de>:
>> On 18.01.2011 20:21, Hernan Olivera wrote:
>>> Hi
>>> I'm working with 2.7 rc1 on CentOS, with the installing script and all
>>> dependencies ok.
>>> Now mapbender_setup.php looks good, except for the line error logging:
>>> Unable to open or generate
>>> /opt/mapbender_2.7/core/../log/mb_error_2011_01_18.log.
>>> This is the ls -l report on the log dir:
>>> drw-rw-rw- 2 apache apache 4096 ene 18 15:22 log
>> try changing the permissions so the directory is executable (means you
>> can change to that dir)
>> chmod +x log
> Hi Thomas
> I've tried +x and 777, with the same results.
> The user and group is apache, which is the apache user, like www-data in debian.
> I'll try isolating the php code, but I've seen a lor of strange things
> with CentOS.
> I've disabled error logging in mapbender, with the same results,
> waiting forever to load app.
> thanks
>> Thomas
>> Thomas Baschetti - Systemanalyse Geographische Informationssysteme
>> Hakenstraße 8D
>> 49074 Osnabrück
>> Tel: 0541 25 91 90 | mobil 01577 189 25 91
>> E-Mail: info at thomas-baschetti.de
>> www.thomas-baschetti.de
>> Ust-IdNr.: DE264355072
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Hernan Olivera
Hernan Olivera
More information about the Mapbender_users
