[Mapbender-users] 2.7 rc1 problem
Hernan Olivera
lholivera at gmail.com
Wed Jan 19 08:13:59 EST 2011
News:
I've installed 2.6.2 in the same machine, withouth any problem.
Now this is my scenario:
1) Solve 2.7 problems to work
2) Use 2.6.2, but need to know what to do to use Openlayers example.
Someone can help?
By the way, I'm trying to make an Openlayers App with google maps
included, inside mapbender.
saludos
2011/1/19 Hernan Olivera <lholivera at gmail.com>:
> Hi
> I've solved the problem (selinux=disabled) for log files. Now setup is
> all green :)
> But mapbender does not load apps: Mapbender 2.7 rc1...loading
> application 'gui1'
> Where to look now?
> 2011/1/18 Hernan Olivera <lholivera at gmail.com>:
>> 2011/1/18 Thomas Baschetti <info at thomas-baschetti.de>:
>>> On 18.01.2011 20:21, Hernan Olivera wrote:
>>>> Hi
>>>> I'm working with 2.7 rc1 on CentOS, with the installing script and all
>>>> dependencies ok.
>>>> Now mapbender_setup.php looks good, except for the line error logging:
>>>> Unable to open or generate
>>>> /opt/mapbender_2.7/core/../log/mb_error_2011_01_18.log.
>>>> This is the ls -l report on the log dir:
>>>> drw-rw-rw- 2 apache apache 4096 ene 18 15:22 log
>>> try changing the permissions so the directory is executable (means you
>>> can change to that dir)
>>> chmod +x log
>> Hi Thomas
>> I've tried +x and 777, with the same results.
>> The user and group is apache, which is the apache user, like www-data in debian.
>> I'll try isolating the php code, but I've seen a lor of strange things
>> with CentOS.
>> I've disabled error logging in mapbender, with the same results,
>> waiting forever to load app.
>> thanks
>>> Thomas
>>> Thomas Baschetti - Systemanalyse Geographische Informationssysteme
>>> Hakenstraße 8D
>>> 49074 Osnabrück
>>> Tel: 0541 25 91 90 | mobil 01577 189 25 91
>>> E-Mail: info at thomas-baschetti.de
>>> www.thomas-baschetti.de
>>> Ust-IdNr.: DE264355072
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Hernan Olivera
> Hernan Olivera
Hernan Olivera
More information about the Mapbender_users
