[Mapbender-users] 2.7 rc1 problem
Hernan Olivera
lholivera at gmail.com
Wed Jan 19 13:16:36 EST 2011
2011/1/19 Thoralf Kauk <tkauk at t-online.de>:
> Am 19.01.2011 14:13, schrieb Hernan Olivera:
>> News:
>> I've installed 2.6.2 in the same machine, withouth any problem.
>> Now this is my scenario:
>> 1) Solve 2.7 problems to work
>> 2) Use 2.6.2, but need to know what to do to use Openlayers example.
>> Someone can help?
> Is the openlayer template app working?
> Do you get the admin apps workink ?
Now I see that admin apps, gui and gui_digitize are ok,
but gui1 y gui2 hangs (in 2.6.2)
No apps working in 2.7
Seeking.....
> Perhaps this is a similar problem as under Win 7 ( file_get_contents
> with complete url [ala http://localhost/mapbender/....] doesn't work).
> You can try to comment out the file_get_contents in
> http\javascripts\initWmcObj.php
> on line 413.
> Thoralf
>> By the way, I'm trying to make an Openlayers App with google maps
>> included, inside mapbender.
>> saludos
>> 2011/1/19 Hernan Olivera <lholivera at gmail.com>:
>>> Hi
>>> I've solved the problem (selinux=disabled) for log files. Now setup is
>>> all green :)
>>> But mapbender does not load apps: Mapbender 2.7 rc1...loading
>>> application 'gui1'
>>> Where to look now?
>>> 2011/1/18 Hernan Olivera <lholivera at gmail.com>:
>>>> 2011/1/18 Thomas Baschetti <info at thomas-baschetti.de>:
>>>>> On 18.01.2011 20:21, Hernan Olivera wrote:
>>>>>> Hi
>>>>>> I'm working with 2.7 rc1 on CentOS, with the installing script and all
>>>>>> dependencies ok.
>>>>>> Now mapbender_setup.php looks good, except for the line error logging:
>>>>>> Unable to open or generate
>>>>>> /opt/mapbender_2.7/core/../log/mb_error_2011_01_18.log.
>>>>>> This is the ls -l report on the log dir:
>>>>>> drw-rw-rw- 2 apache apache 4096 ene 18 15:22 log
>>>>> try changing the permissions so the directory is executable (means you
>>>>> can change to that dir)
>>>>> chmod +x log
>>>> Hi Thomas
>>>> I've tried +x and 777, with the same results.
>>>> The user and group is apache, which is the apache user, like www-data in debian.
>>>> I'll try isolating the php code, but I've seen a lor of strange things
>>>> with CentOS.
>>>> I've disabled error logging in mapbender, with the same results,
>>>> waiting forever to load app.
>>>> thanks
>>>>> Thomas
>>>>> Thomas Baschetti - Systemanalyse Geographische Informationssysteme
>>>>> Hakenstraße 8D
>>>>> 49074 Osnabrück
>>>>> Tel: 0541 25 91 90 | mobil 01577 189 25 91
>>>>> E-Mail: info at thomas-baschetti.de
>>>>> www.thomas-baschetti.de
>>>>> Ust-IdNr.: DE264355072
>>>>> _______________________________________________
>>>>> Mapbender_users mailing list
>>>>> Mapbender_users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>>> Hernan Olivera
>>> Hernan Olivera
Hernan Olivera
More information about the Mapbender_users
