[Mapbender-users] 2.7 rc1 problem
Hernan Olivera lholivera at gmail.com
Wed Jan 19 14:25:14 EST 2011
Update:
2011/1/19 Hernan Olivera <lholivera at gmail.com>:
> 2011/1/19 Thoralf Kauk <tkauk at t-online.de>:
>> Am 19.01.2011 14:13, schrieb Hernan Olivera:
>>> News:
>>> I've installed 2.6.2 in the same machine, withouth any problem.
>>> Now this is my scenario:
>>> 1) Solve 2.7 problems to work
>>> 2) Use 2.6.2, but need to know what to do to use Openlayers example.
>>> Someone can help?
>> Is the openlayer template app working?
>> Do you get the admin apps workink ?
> Now I see that admin apps, gui and gui_digitize are ok,
> but gui1 y gui2 hangs (in 2.6.2)
Found in error_log:
[Wed Jan 19 15:38:26 2011] [error] [client 127.0.0.1] File does not
exist: /opt/mapbender_2.6.2/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/.ui.tabs.js,
referer: http://localhost/mapbender262/frames/login.php
fixed, eliminating the initial point in file name.
[Wed Jan 19 15:59:00 2011] [error] [client 127.0.0.1] PHP Fatal error:
 Class 'DOMDocument' not found in
/opt/mapbender_2.6.2/http/classes/class_wmcToXml.php on line 66,
referer: http://localhost/mapbender262/frames/index.php?&gui_id=gui1
fixed, installing php-xml an restarting apache.
> No apps working in 2.7
I like something to look for here...
> Seeking.....
>> Perhaps this is a similar problem as under Win 7 ( file_get_contents
>> with complete url [ala http://localhost/mapbender/....] doesn't work).
>> You can try to comment out the file_get_contents in
>> http\javascripts\initWmcObj.php
>> on line 413.
>> Thoralf
>>> By the way, I'm trying to make an Openlayers App with google maps
>>> included, inside mapbender.
>>> saludos
>>>> Hi
>>>> I've solved the problem (selinux=disabled) for log files. Now setup is
>>>> all green :)
>>>> But mapbender does not load apps:  Mapbender 2.7 rc1...loading
>>>> application 'gui1'
>>>> Where to look now?
>>>> 2011/1/18 Hernan Olivera <lholivera at gmail.com>:
>>>>> 2011/1/18 Thomas Baschetti <info at thomas-baschetti.de>:
>>>>>> On 18.01.2011 20:21, Hernan Olivera wrote:
>>>>>>> Hi
>>>>>>> I'm working with 2.7 rc1 on CentOS, with the installing script and all
>>>>>>> dependencies ok.
>>>>>>> Now mapbender_setup.php looks good, except for the line error logging:
>>>>>>> Unable to open or generate
>>>>>>> /opt/mapbender_2.7/core/../log/mb_error_2011_01_18.log.
>>>>>>> This is the ls -l report on the log dir:
>>>>>>> drw-rw-rw-  2 apache apache  4096 ene 18 15:22 log
>>>>>> try changing the permissions so the directory is executable (means you
>>>>>> can change to that dir)
>>>>>> chmod +x log
>>>>> Hi Thomas
>>>>> I've tried +x and 777, with the same results.
>>>>> The user and group is apache, which is the apache user, like www-data in debian.
>>>>> I'll try isolating the php code, but I've seen a lor of strange things
>>>>> with CentOS.
>>>>> I've disabled error logging in mapbender, with the same results,
>>>>> waiting forever to load app.
>>>>> thanks
>>>>>> Thomas
>>>>>> Thomas Baschetti - Systemanalyse Geographische Informationssysteme
>>>>>> Hakenstraße 8D
>>>>>> 49074 Osnabrück
>>>>>> Tel: 0541 25 91 90 | mobil 01577 189 25 91
>>>>>> E-Mail: info at thomas-baschetti.de
>>>>>> www.thomas-baschetti.de
>>>>>> Ust-IdNr.: DE264355072
>>>>>> _______________________________________________
>>>>>> Mapbender_users mailing list
>>>>>> Mapbender_users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>>>> Hernan Olivera
>>>> Hernan Olivera
> Hernan Olivera
Hernan Olivera
More information about the Mapbender_users mailing list
