[Mapbender-users] 2.7 rc1 problem
Hernan Olivera lholivera at gmail.com
Mon Jan 24 09:19:25 EST 2011
2011/1/24 Manns, Marc <manns at str.de>:
> Hi Hernan,
> there's a problem with an ui-element in
> this application.
> I fixed it in 2.7 branch and trunk.
> see:
> http://trac.osgeo.org/mapbender/changeset/7411
> Just load this sql in your mapbender database
> and it should be fixed.
> regards marc
Thanks a lot!
regards
> -----Ursprüngliche Nachricht-----
> Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Hernan Olivera
> Gesendet: Freitag, 21. Januar 2011 16:43
> An: Mapbender User List
> Betreff: Re: [Mapbender-users] 2.7 rc1 problem
> Hi
> OpenLayers example does not function (loading...) in 2.7 rc1, but is ok in 2.7 alpha.
> I've tested it on two different configurations.
> Someone reporting the same?
> 2011/1/19 Hernan Olivera <lholivera at gmail.com>:
>> Ok.
>> I have downloaded again 2.7 rc1, reinstalled from scratch and all is
>> working well.
>> I can't explain this. Maybe a newer 2.7?
>> Thanks. I've learned a lot :)
>>>> Thanks. But I think these are not real errors. We should mark them
>>>> as notices.
>>> Ok, I've set ALL & NOTICE,
>>>> Any chance you got sth in your PHP error log? You can enable it in
>>>> php.ini, sth. like
>>>> logErrors = On
>>>> errorLog = <filename>
>>> Here it is:
>>> [19-Jan-2011 07:50:32] PHP Warning:  Module 'gd' already loaded in
>>> Unknown on line 0
>>> [19-Jan-2011 07:50:32] PHP Warning:  Module 'imagick' already loaded
>>> in Unknown on line 0
>>> [19-Jan-2011 07:50:32] PHP Warning:  Module 'pgsql' already loaded in
>>> Unknown on line 0
>>> [19-Jan-2011 09:06:40] PHP Warning:  Module 'gd' already loaded in
>>> Unknown on line 0
>>> [19-Jan-2011 09:06:40] PHP Warning:  Module 'imagick' already loaded
>>> [19-Jan-2011 09:06:40] PHP Warning:  Module 'pgsql' already loaded in
>>> Unknown on line 0
>>> [19-Jan-2011 09:09:08] PHP Warning:  Module 'gd' already loaded in
>>> Unknown on line 0
>>> [19-Jan-2011 09:09:08] PHP Warning:  Module 'imagick' already loaded
>>> [19-Jan-2011 09:09:08] PHP Warning:  Module 'pgsql' already loaded in
>>> Unknown on line 0
>>> [19-Jan-2011 10:08:06] PHP Warning:  Module 'gd' already loaded in
>>> Unknown on line 0
>>> [19-Jan-2011 10:08:06] PHP Warning:  Module 'imagick' already loaded
>>> [19-Jan-2011 10:08:06] PHP Warning:  Module 'pgsql' already loaded in
>>> Unknown on line 0
>>> [19-Jan-2011 10:08:17] PHP Warning:  Module 'gd' already loaded in
>>> Unknown on line 0
>>> [19-Jan-2011 10:08:17] PHP Warning:  Module 'imagick' already loaded
>>> [19-Jan-2011 10:08:17] PHP Warning:  Module 'pgsql' already loaded in
>>> Unknown on line 0
>>> [19-Jan-2011 16:20:34] PHP Warning:  Module 'gd' already loaded in
>>> Unknown on line 0
>>> [19-Jan-2011 16:20:34] PHP Warning:  Module 'imagick' already loaded
>>> [19-Jan-2011 16:20:34] PHP Warning:  Module 'pgsql' already loaded in
>>> Unknown on line 0
>>> [19-Jan-2011 16:45:07] PHP Warning:  Module 'gd' already loaded in
>>> Unknown on line 0
>>> [19-Jan-2011 16:45:07] PHP Warning:  Module 'imagick' already loaded
>>> [19-Jan-2011 16:45:07] PHP Warning:  Module 'pgsql' already loaded in
>>> Unknown on line 0
>>> [19-Jan-2011 17:54:17] PHP Warning:  Module 'gd' already loaded in
>>> Unknown on line 0
>>> [19-Jan-2011 17:54:17] PHP Warning:  Module 'imagick' already loaded
>>> [19-Jan-2011 17:54:17] PHP Warning:  Module 'pgsql' already loaded in
>>> Unknown on line 0
>>>> Sounds like an untested PHP/Apache/Postgres configuration .. never
>>>> heard of so much hassle with an installation.
>>> I have no problems now with 2.6.2.
>>> mapbender_setup.php says all ok in both versions And.. yes, CentOS is
>>> a nightmare.
>>> By the way, can I import the OpenLayers example of 2.7 in 2.6.2, or I
>>> need another version of the app?
>>> thanks
>>>> Thanks,
>>>> Christoph
>>>>>> 2011/1/19 Christoph Baudson <christoph at baudson.de>:
>>>>>>> -----BEGIN PGP SIGNED MESSAGE-----
>>>>>>> Hash: SHA1
>>>>>>> On 01/19/2011 07:16 PM, Hernan Olivera wrote:
>>>>>>>> 2011/1/19 Thoralf Kauk <tkauk at t-online.de>:
>>>>>>>>> Am 19.01.2011 14:13, schrieb Hernan Olivera:
>>>>>>>>>> News:
>>>>>>>>>> I've installed 2.6.2 in the same machine, withouth any problem.
>>>>>>>>>> Now this is my scenario:
>>>>>>>>>> 1) Solve 2.7 problems to work
>>>>>>>>>> 2) Use 2.6.2, but need to know what to do to use Openlayers example.
>>>>>>>>>> Someone can help?
>>>>>>> Hi Hernan, pleae install Firebug and check for JavaScript error messages.
>>>>>> I'm just doing that. There's no errors reported by firebug in 2.7
>>>>>> apps (that hangs 'loading applicattion gui, gui1, gui2...').
>>>>>> But I can see that the head section ends after the title and then
>>>>>> all css is in the body.
>>>>>> But this is what firebug shows. If I look at the source code of
>>>>>> the page as is shown by firefox, the head section closes after all css.
>>>>>> Strange...
>>>>>> Searching...
>>>>>> Hernan Olivera
>>>>> _______________________________________________
>>>>> Mapbender_users mailing list
>>>>> Mapbender_users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>>> -----BEGIN PGP SIGNATURE-----
>>>> Version: GnuPG v1.4.10 (GNU/Linux)
>>>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
>>>> iEYEARECAAYFAk03Vo0ACgkQGtMIfbycMX7v8wCfTXSYX4qu3ChNvqgVWMPdT6Ol
>>>> p3UAn16SEriExsLeEBSwFuEYCdPXQj/N
>>>> =qeAb
>>>> -----END PGP SIGNATURE-----
>>> Hernan Olivera
>> Hernan Olivera
> Hernan Olivera
Hernan Olivera
More information about the Mapbender_users mailing list
