[Mapbender-users] Probleme bei Logging
Sven Böhme
boehme at supportgis.de
Fri Jan 28 02:39:07 EST 2011
Hallo Liste!
Ich habe ein Problem beim Logging des Mapbenders.
Und zwar werden in das error.log file des Apache
sehr viele errors geschrieben. Diese scheinend as
System nicht weiter zu stören, da es fehlerfrei
läuft. Das Logfile wird jedoch sehr sehr groß, was
zu Problemen führt. Wie kann ich das Logging
abstellen? Oder wie kann ich die aufgetretenen
Fehlermeldungen abstellen:
[Thu Jan 27 16:10:43 2011] [error] [client
91.43.88.112] PHP Notice: Use of undefined
constant GEOS_DBSERVER - assumed 'GEOS_DBSERVER'
in
/srv/www/htdocs/mapbender_2.6/conf/mapbender.conf
on line 161, referer:
http://www.landentwicklung-online.thueringen.de/?pid=3&id=521&vaz=3-9-0437
constant GEOS_DB - assumed 'GEOS_DB' in
on line 162, referer:
constant GEOS_PORT - assumed 'GEOS_PORT' in
on line 163, referer:
constant GEOS_OWNER - assumed 'GEOS_OWNER' in
on line 164, referer:
constant GEOS_PW - assumed 'GEOS_PW' in
on line 165, referer:
91.43.88.112] PHP Notice: Undefined index:
mb_lang in
/srv/www/htdocs/mapbender_2.6/core/globalSettings.php
on line 64, referer:
91.43.88.112] PHP Notice: Undefined property:
Mb_locale::$knownLocales in
/srv/www/htdocs/mapbender_2.6/http/classes/class_locale.php
on line 153, referer:
91.43.88.112] PHP Notice: A session had already
been started - ignoring session_start() in
/srv/www/htdocs/mapbender_2.6/http/frames/login.php on
line 59, referer:
mb_myBBOX in
/srv/www/htdocs/mapbender_2.6/conf/session.conf on
line 6, referer:
kml_id in
line 7, referer:
mb_myPOI in
line 8, referer:
mb_myPOI2SCALE in
line 9, referer:
91.43.88.112] PHP Notice: Undefined index: lang
in /srv/www/htdocs/mapbender_2.6/conf/session.conf
on line 11, referer:
COMMAND in
line 13, referer:
91.43.88.112] PHP Notice: Undefined index: wms1
on line 17, referer:
wmc_id in
line 25, referer:
merge_wmc_id in
line 29, referer:
append_wmc_id in
line 33, referer:
[Thu Jan 27 16:10:47 2011] [error] [client
legendformat in
/srv/www/htdocs/mapbender_2.6/http/classes/class_wms.php
on line 1059, referer:
http://www.landentwicklung-online.thueringen.de/mapbender/frames/index.php?&gui_id=Kartenviewer
wms::$gui_epsg in
/srv/www/htdocs/mapbender_2.6/http/classes/class_wmcToXml.php
on line 368, referer:
constant tag - assumed 'tag' in
/srv/www/htdocs/mapbender_2.6/http/classes/class_wmc.php
on line 501, referer:
on line 502, referer:
constant type - assumed 'type' in
on line 503, referer:
constant attributes - assumed 'attributes' in
on line 504, referer:
constant value - assumed 'value' in
on line 505, referer:
91.43.88.112] PHP Notice: Undefined index: value
in
Vielen Dank für eure Hilfe!
Gruß
Sven
More information about the Mapbender_users
