[Mapbender-users] WMS geoserver-mapbender error
Valenty Gonzalez gvalenty at gmail.com
Fri Jan 28 14:09:05 EST 2011
  Thanks so much Hernan, i will probe a let you know.
Regards,
El 28/01/2011 02:37 p.m., Hernan Olivera escribió:
> Hello
> If this helps, I have received the same error, maybe there is
> something wrong in the installation.
> I fixed this making a fresh install.
> greeetings
> 2011/1/28 Valenty Gonzalez<gvalenty at gmail.com>:
>> I have been working with geoserver-2.0.2 for a
>> new project in which we use as a portalMapbender.
>> I have a problem, mapbender do not read the wms from geoserver
>> I've also done a test with GeoWebCache where you can
>> make a configuration forserving the tiles (wmst) like
>> wms and I've verified that it works in gvSIG.
>> but I get the same error in mapbender; mapbender can't read it.
>> I send the error that report Mapbender and the GetCapabilities file.
>> Mapbender error:
>> file: http://192.168.0.169:8080/geoserver/wms?SERVICE=WMS&REQUEST=GetCapabilities&version=1.1.1sql error: ERROR: insert
>> or update on table "layer_keyword" violates foreign
>> key'fkey_layer_id_fkey_keyword_id "DETAIL: Key (fkey_layer_id)
>> = (20,139) is notpresent in table 'layer'. Performed ROLLBACK ....
>> Any idea?
>> Thanks in advance
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
