[Mapbender-users] WMS geoserver-mapbender error
Astrid Emde
astrid.emde at wheregroup.com
Sat Jan 29 13:49:13 EST 2011
Hello Valenty, hello Hernan,
I discoverd the same problem. This is a Mapbender bug.
I opened a ticket:
http://trac.osgeo.org/mapbender/ticket/768
I hope we will fix this error on monday.
Astrid
On Fri, January 28, 2011 7:09 pm, Valenty Gonzalez wrote:
> Thanks so much Hernan, i will probe a let you know.
> Regards,
> El 28/01/2011 02:37 p.m., Hernan Olivera escribió:
>> Hello
>> If this helps, I have received the same error, maybe there is
>> something wrong in the installation. I fixed this making a fresh install.
>> greeetings
>> 2011/1/28 Valenty Gonzalez<gvalenty at gmail.com>:
>>> I have been working with geoserver-2.0.2 for a
>>> new project in which we use as a portalMapbender.
>>> I have a problem, mapbender do not read the wms from geoserver
>>> I've also done a test with GeoWebCache where you can
>>> make a configuration forserving the tiles (wmst) like wms and I've
>>> verified that it works in gvSIG. but I get the same error in
>>> mapbender; mapbender can't read it.
>>> I send the error that report Mapbender and the GetCapabilities file.
>>> Mapbender error:
>>> file:
>>> http://192.168.0.169:8080/geoserver/wms?SERVICE=WMS&REQUEST=GetCapabi
>>> lities&version=1.1.1sql error: ERROR: insert or update on table
>>> "layer_keyword" violates foreign
>>> key'fkey_layer_id_fkey_keyword_id "DETAIL: Key (fkey_layer_id) =
>>> (20,139) is notpresent in table 'layer'. Performed ROLLBACK ....
>>> Any idea?
>>> Thanks in advance
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
Die WhereGroup zieht um ...
Ab dem 01.01.2011 lautet unsere neue Adresse:
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Alle Telefonnummern und eMail-Adressen
bleiben unverändert.
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
