[Mapbender-users] WMS geoserver-mapbender error
Valenty Gonzalez
gvalenty at gmail.com
Sat Jan 29 14:50:16 EST 2011
Thanks Astrid!
Hernan i have probe macking a new installation and i get same error.
So, i have installed mapbender-2.6.2 and "load mws" with the same server
and work fine.
It's a bug in mapbender-2.7;
Astrid i will wait your notice; i have connect mapbender-2.6.2 with
geoserver-2.0.2 and with geowebcache-1.2.4 (similar to tile cache) wich
is something important for all us.
But i want to probe connect in mapbender-2.7 because i will have
mapbender like web client of all service of my sdi node: wms, wfs,
gazzeter, csw (this it's a capbilities of mb-2.7) and wmst and this will
be really nice :-)
Regards,
El 29/01/2011 02:19 p.m., Astrid Emde escribió:
> Hello Valenty, hello Hernan,
> I discoverd the same problem. This is a Mapbender bug.
> I opened a ticket:
> http://trac.osgeo.org/mapbender/ticket/768
> I hope we will fix this error on monday.
> Astrid
> On Fri, January 28, 2011 7:09 pm, Valenty Gonzalez wrote:
>> Thanks so much Hernan, i will probe a let you know.
>> Regards,
>> El 28/01/2011 02:37 p.m., Hernan Olivera escribió:
>>> Hello
>>> If this helps, I have received the same error, maybe there is
>>> something wrong in the installation. I fixed this making a fresh install.
>>> greeetings
>>> 2011/1/28 Valenty Gonzalez<gvalenty at gmail.com>:
>>>> I have been working with geoserver-2.0.2 for a
>>>> new project in which we use as a portalMapbender.
>>>> I have a problem, mapbender do not read the wms from geoserver
>>>> I've also done a test with GeoWebCache where you can
>>>> make a configuration forserving the tiles (wmst) like wms and I've
>>>> verified that it works in gvSIG. but I get the same error in
>>>> mapbender; mapbender can't read it.
>>>> I send the error that report Mapbender and the GetCapabilities file.
>>>> Mapbender error:
>>>> file:
>>>> http://192.168.0.169:8080/geoserver/wms?SERVICE=WMS&REQUEST=GetCapabi
>>>> lities&version=1.1.1sql error: ERROR: insert or update on table
>>>> "layer_keyword" violates foreign
>>>> key'fkey_layer_id_fkey_keyword_id "DETAIL: Key (fkey_layer_id) =
>>>> (20,139) is notpresent in table 'layer'. Performed ROLLBACK ....
>>>> Any idea?
>>>> Thanks in advance
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
