[Mapbender-users] WMS geoserver-mapbender error
Astrid Emde astrid.emde at wheregroup.com
Mon Jan 31 16:28:17 EST 2011
Hello,
 I fixed the error in trunk and 2.7.
See also:
http://trac.osgeo.org/mapbender/ticket/768
http://trac.osgeo.org/mapbender/changeset/7505
Best regards Astrid
On Sat, January 29, 2011 7:50 pm, Valenty Gonzalez wrote:
> Thanks Astrid!
> Hernan i have probe macking a new installation and i get same error.
> So, i have installed mapbender-2.6.2 and "load mws" with the same server
> and work fine.
> It's a bug in mapbender-2.7;
> Astrid i will wait your notice; i have connect mapbender-2.6.2 with
> geoserver-2.0.2 and with geowebcache-1.2.4 (similar to tile cache) wich is
> something important for all us. But i want to probe connect in
> mapbender-2.7 because i will have mapbender like web client of all service
> of my sdi node: wms, wfs, gazzeter, csw (this it's a capbilities of
> mb-2.7) and wmst and this will be really nice :-)
> Regards,
> El 29/01/2011 02:19 p.m., Astrid Emde escribió:
>> Hello Valenty, hello Hernan,
>> I discoverd the same problem. This is a Mapbender bug.
>> I opened a ticket:
>> I hope we will fix this error on monday.
>> Astrid
>> On Fri, January 28, 2011 7:09 pm, Valenty Gonzalez wrote:
>>> Thanks so much Hernan, i will probe a let you know.
>>> Regards,
>>> El 28/01/2011 02:37 p.m., Hernan Olivera escribió:
>>>> Hello
>>>> If this helps, I have received the same error, maybe there is
>>>> something wrong in the installation. I fixed this making a fresh
>>>> install.
>>>> greeetings
>>>> 2011/1/28 Valenty Gonzalez<gvalenty at gmail.com>:
>>>>> I have been working with geoserver-2.0.2 for a
>>>>> new project in which we use as a portalMapbender.
>>>>> I have a problem, mapbender do not read the wms from geoserver
>>>>> I've also done a test with GeoWebCache where you can
>>>>> make a configuration forserving the tiles (wmst) like wms and I've
>>>>>  verified that it works in gvSIG. but I get the same error in
>>>>> mapbender; mapbender can't read it.
>>>>> I send the error that report Mapbender and the GetCapabilities
>>>>> file.
>>>>> Mapbender error:
>>>>> file:
>>>>> http://192.168.0.169:8080/geoserver/wms?SERVICE=WMS&REQUEST=GetCap
>>>>> abi lities&version=1.1.1sql error: ERROR: insert or update on
>>>>> table "layer_keyword" violates foreign
>>>>> key'fkey_layer_id_fkey_keyword_id "DETAIL: Key (fkey_layer_id) =
>>>>> (20,139) is notpresent in table 'layer'. Performed ROLLBACK ....
>>>>> Any idea?
>>>>> Thanks in advance
>>>>> _______________________________________________
>>>>> Mapbender_users mailing list
>>>>> Mapbender_users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
Die WhereGroup zieht um ...
Ab dem 01.01.2011 lautet unsere neue Adresse:
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Alle Telefonnummern und eMail-Adressen
bleiben unverändert.
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
