[Mapbender-users] WMS geoserver-mapbender error
Valenty Gonzalez
gvalenty at gmail.com
Mon Jan 31 17:01:01 EST 2011
Astrid thank you very much
I've tried and it worked!
Once i have finished setting ogc services will forward the result. I
think it will be aninteresting case study.
Thanks again,
Regards,
El 31/01/2011 04:58 p.m., Astrid Emde escribió:
> Hello,
> I fixed the error in trunk and 2.7.
> See also:
> http://trac.osgeo.org/mapbender/ticket/768
> http://trac.osgeo.org/mapbender/changeset/7505
> Best regards Astrid
> On Sat, January 29, 2011 7:50 pm, Valenty Gonzalez wrote:
>> Thanks Astrid!
>> Hernan i have probe macking a new installation and i get same error.
>> So, i have installed mapbender-2.6.2 and "load mws" with the same server
>> and work fine.
>> It's a bug in mapbender-2.7;
>> Astrid i will wait your notice; i have connect mapbender-2.6.2 with
>> geoserver-2.0.2 and with geowebcache-1.2.4 (similar to tile cache) wich is
>> something important for all us. But i want to probe connect in
>> mapbender-2.7 because i will have mapbender like web client of all service
>> of my sdi node: wms, wfs, gazzeter, csw (this it's a capbilities of
>> mb-2.7) and wmst and this will be really nice :-)
>> Regards,
>> El 29/01/2011 02:19 p.m., Astrid Emde escribió:
>>> Hello Valenty, hello Hernan,
>>> I discoverd the same problem. This is a Mapbender bug.
>>> I opened a ticket:
>>> I hope we will fix this error on monday.
>>> Astrid
>>> On Fri, January 28, 2011 7:09 pm, Valenty Gonzalez wrote:
>>>> Thanks so much Hernan, i will probe a let you know.
>>>> Regards,
>>>> El 28/01/2011 02:37 p.m., Hernan Olivera escribió:
>>>>> Hello
>>>>> If this helps, I have received the same error, maybe there is
>>>>> something wrong in the installation. I fixed this making a fresh
>>>>> install.
>>>>> greeetings
>>>>> 2011/1/28 Valenty Gonzalez<gvalenty at gmail.com>:
>>>>>> I have been working with geoserver-2.0.2 for a
>>>>>> new project in which we use as a portalMapbender.
>>>>>> I have a problem, mapbender do not read the wms from geoserver
>>>>>> I've also done a test with GeoWebCache where you can
>>>>>> make a configuration forserving the tiles (wmst) like wms and I've
>>>>>> verified that it works in gvSIG. but I get the same error in
>>>>>> mapbender; mapbender can't read it.
>>>>>> I send the error that report Mapbender and the GetCapabilities
>>>>>> file.
>>>>>> Mapbender error:
>>>>>> file:
>>>>>> http://192.168.0.169:8080/geoserver/wms?SERVICE=WMS&REQUEST=GetCap
>>>>>> abi lities&version=1.1.1sql error: ERROR: insert or update on
>>>>>> table "layer_keyword" violates foreign
>>>>>> key'fkey_layer_id_fkey_keyword_id "DETAIL: Key (fkey_layer_id) =
>>>>>> (20,139) is notpresent in table 'layer'. Performed ROLLBACK ....
>>>>>> Any idea?
>>>>>> Thanks in advance
>>>>>> _______________________________________________
>>>>>> Mapbender_users mailing list
>>>>>> Mapbender_users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20110131/80bf0762/attachment.html
More information about the Mapbender_users
