[Mapbender-users] Re: Problem accessing Mapbender
Juan Jose Marti Navio­ marti_jjo at gva.es
Wed Jun 8 09:54:56 EDT 2011
Hi Astrid.
I've done that I dijsite of mapbender_setup.php and effectively, to open
in [1] is an error with the connection to the database:
PostGIS PostGIS support function not available
pg_query (Resource id # 13, select postgis_full_version ();)
The truth is not that SIGINFO that mistake, I will seek information and
consult to see if I can fix this error.
Thank you very much for your help, I hope to soon intalar Mapbender.
Greetings and thanks
Juanjo.
http://localhost/mapbender/tmp/mapbender_setup.php
Hola Astrid.
He hecho eso que me dijsite de mapbender_setup.php y efectivamente, al
abrirlo en [1] se aparece un error con la conexion de la base de datos:
PostGIS support  no PostGIS function available
pg_query(Resource id #13,select postgis_full_version();)
La verdad que no se que siginfica ese error, voy a buscar informacion y
consultarlo a ver si consigo arreglar ese error.
Muchas gracias por tu ayuda, espero poder intalarme pronto mapbender.
Saludos y gracias
Juanjo.
 >Hola Juanjo,
 >it looks like your database connection is not set up yet.
 >Mapbender provides a file called mapbender_setup.php which you can
call to
 >find out whether everything is all right.
 >You will find the file at mapbender/tools/mapbender_setup.php. Please
copy
 >the file to
 >mapbender/http/tmp/mapbender_setup.php
 >Then open your browser and refer to the file maybe like this:
 >If everything is allright you will see lot of green comments. Maybe some
 >parts will be red and you will see at which part you can look for the
 >error (not database connection, missing php extensions..)
 >Hope this will help.
 >Read more about the Mapbender installation at:
 >http://www.mapbender.org/Installation_en
 >Best regards
 >Astrid
 >On Thu, June 2, 2011 2:09 pm, Juan Jose Marti Navio­ wrote:
 > Hi good afternoon my name is Juan Jose is my first message on the
 > mailing list Mapbender.
 > I'm new to Mapbender, and once I have installed problamas to enter.
 > Excuse for my English is very limited. I've been looking for old
 > messages and no information about my doubts, but nevertheless, I can not
 > resolve it.
 > I've installed Windows XP Mapbender but I have trouble accessing. I
 > followed the instructions I have found useful guidance in the live of
osgeo
 > [1] where I said that I can login with the user root and password
 > root. I log in with that username and password and click login I open
a new
 > window again asked the name and password. I rewrite root and root, and I
 > feel the same, I go into a loop where I re-open a window to ask me for
 > data access.
 > On the other hand I tried to create me a new username and password but I
 > feel the same, I opened the window and asks for more data access.
Someone
 > do something similar happened? What can be?
 > Thank you very much.
 > Greetings
 > Juanjo.
 > [1]http://live.osgeo.org/es/quickstart/mapbender_quickstart.html
 > Hola buenas tardes me llamo Juan Jose es mi primer mensaje en la lista
 > de correo de Mapbender.
 > Soy nuevo con Mapbender, y una vez instalado tengo problamas para
 > acceder. Disculpar por mi ingles que es muy limitado. He estado buscando
 > por mensajes antiguos y hay informacion sobre mi duda, pero pese a ello,
 > no consigo resolverla.
 > Me he instalado Mapbender en Windows XP pero tengo problemas para
 > acceder. He seguido las instrucciones de la guía útil que he
encontrado en
 > el live de osgeo [1] donde me dice que puedo ingresar con al usuario
root
 > y la contraseña root. Intento acceder con ese usuario y contraseña y al
 > hacer clic en login se me abre una nueva ventana volviéndome a pedir el
 > name y el password. Vuelvo a escribir root y root y me pasa lo mismo,
 > entro en un bucle donde se me vuelve a abrir una ventana para pedirme
los
 > datos de acceso.
 > Por otra parte he intentado crearme un nuevo usuario y contraseña pero
 > me pasa lo mismo, se me abre la ventana y me pide otra vez los datos de
 > acceso. ¿A Alguien le ha pasado algo similar? ¿A que puede ser debido?
 > Muchas gracias.
 > Saludos
 > Juanjo.
 > Proyecto gvSIG
 > Consellería de Infraestructuras y Transportes (GVA)
 > Valencia (España)
 > Mapbender_users mailing list
 > [hidden email]
<http://osgeo-org.1803224.n2.nabble.com/user/SendEmail.jtp?type=node&node=6435556&i=0>
 > http://lists.osgeo.org/mailman/listinfo/mapbender_users
«  [hide part of quote
<http://osgeo-org.1803224.n2.nabble.com/Problem-accessing-Mapbender-td6431319.html#>]
Mit freundlichen Grüßen
Astrid Emde
Proyecto gvSIG
Valencia (España)
More information about the Mapbender_users mailing list
