[Mapbender-users] Digitizing question Mapbender 2.7
Astrid Emde astrid.emde at wheregroup.com
Thu Jun 9 04:46:30 EDT 2011
Hello Thijs de Boer,
please make sure that you use Mapbender 2.7.1. There have been some bugs
in 2.7.
http://www.mapbender.org/download/mapbender_2.7.1.zip
There was a bug with WFS update
http://trac.osgeo.org/mapbender/ticket/500
We are working at Mapbender 2.7.2 with more bug fixes.
Best regards Astrid
On Thu, June 9, 2011 8:43 am, Boer, dr. W.M. de (Thijs) wrote:
> Hello list members,
> After setting up WFS-T digitizing with Mapbender 2.7 and PostGIS I
> managed to add new points, lines and polygons and alter them. So far, so
> good. However, ist seems not possible to alter existing objects (f. i.
> put them in a new position or change attributes). What do I have to do to
> get this running ? I use owsproxy. Is there an issue with it regarding
> WSF-T ?
> I'm greatfull for any help.
> Greetings,
> Thijs de Boer
> Dit bericht kan informatie bevatten die niet voor u is bestemd. Indien u
> niet de geadresseerde bent of dit bericht abusievelijk aan u is gezonden,
> wordt u verzocht dat aan de afzender te melden en het bericht te
> verwijderen. De Staat aanvaardt geen aansprakelijkheid voor schade, van
> welke aard ook, die verband houdt met risico's verbonden aan het
> elektronisch verzenden van berichten.
> This message may contain information that is not intended for you. If you
>  are not the addressee or if this message was sent to you by mistake, you
>  are requested to inform the sender and delete the message. The State
> accepts no liability for damage of any kind resulting from the risks
> inherent in the electronic transmission of messages.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
AGIT 2011
6.-8. Juli 2011 in Salzburg
Treffen Sie die WhereGroup an Stand Nr. 30
http://www.agit.at
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
