[Mapbender-users] Digitize GUI and WFS-T: how to edit existing
features (points, polygons) ?
Verena Diewald
verena.diewald at wheregroup.com
Tue Nov 22 04:07:20 EST 2011
Hello Thijs,
did you include the module "setSpatialRequest" into your gui? You need
this module to do a spatial selection in the mapframe to select the
geometry objects you want to edit and transfer them into the working
area of the digitize module.
Greetings,
Verena
Am 22.11.2011 09:54, schrieb Boer, dr. W.M. de (Thijs):
> Dear List,
> In Mapbender 2.7.2 I managed to set up WFS-T and the digitizing GUI all right.
> So now I can add points and polygons. But editing existing points and polygons is not working.
> Should the Gazetteer be configured or should I do something else to get it working ?
> Greetings,
> Thijs de Boer
> Dit bericht kan informatie bevatten die niet voor u is bestemd. Indien u
> niet de geadresseerde bent of dit bericht abusievelijk aan u is gezonden,
> wordt u verzocht dat aan de afzender te melden en het bericht te
> verwijderen.
> De Staat aanvaardt geen aansprakelijkheid voor schade, van welke aard
> ook, die verband houdt met risico's verbonden aan het elektronisch
> verzenden van berichten.
> This message may contain information that is not intended for you. If you
> are not the addressee or if this message was sent to you by mistake, you
> are requested to inform the sender and delete the message.
> The State accepts no liability for damage of any kind resulting from the
> risks inherent in the electronic transmission of messages.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
