[Mapbender-users] Re: GeoServer WMS einbinden
Albert Polze A.Polze at mailbox.tu-berlin.de
Thu Sep 8 07:31:40 EDT 2011
Hey Christian,
I'm sorry, I don't know the solution to your first problem. But for the
second one.., as far as i remeber MB takes the EPSG to start with from the
first layer. This layer isn't the first one you had uploaded to geoserver.
It is, well geoserver itself. I red about somewhere but you get me if you
have a look into your "WMS  Anwendungseinstellung" the EPSG is the one from
Layer Nr. 0.
I think you can solve this problem by referring to the EPSG in your GUI-URL.
You can also use the "Change Projection"-Modul from "gui"-template
But make sure that your EPSG is in the spatial_ref_sys table. If it isn't
http://spatialreference.org/ will help you.
Albert
PS: If you know how to solve both of your problems let me know
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GeoServer-WMS-einbinden-tp6749437p6771397.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users mailing list
