[Mapbender-users] Re: GeoServer WMS einbinden
Astrid Emde astrid.emde at wheregroup.com
Tue Sep 13 00:26:54 EDT 2011
Hello Christian,
Mapbender by default only offers the EPSG codes from the
getCapabilities-XML that offer a BBOX.
But in Mapbender 2.7.x you have a new variable in mapbender.conf called
SRS_ARRAY where you can define a list of EPSG codes you would like to
calculate the BBOX for.
For example
define("SRS_ARRAY", "4326, 31466, 31467, 31468, 25832, 2398");
This should help and you should be able to choose your ESPG code.
Astrid
On Thu, September 8, 2011 10:32 am, Christian Röttger wrote:
> Am 06.09.2011 12:45, schrieb Albert Polze:
>> Hello Christian,
>> I also had a lot of trouble to get my geoserver working. I cannot
>> confirm your assumption of the EPSG-Codes. With Mb 2.7-1 and GS 2.1.1
>> everything works fine. Be cause im also a beginner i don't know if any
>> server-settings are incorrect (server-timeout?) but maybe your
>> Get-Capabilities Request is
>> wrong? Here is mine:
>> http://xxx.xxx.xx.xx:8080/geoserver/wms?REQUEST=GetCapabilities&SERVICE
>> =WMS&VERSION=1.1.1
>> Maybe you should have a look into your geoserver-error.log /
>> request.log ?
>> Greetings Albert
> Hello,
> if i "normally" try to upload my capabilities, this is the answer:
> file:
> http://server:8080/geoserver/vietnam/wms?REQUEST=GetCapabilities&SERVICE=W
> MS&VERSION=1.1.1
> When i add my EPSG code to a limited SRS list in geoserver wms, the
> upload works.
> I wonder if this problem is geoserver or mapbender related.
> The next problem is that i can only choose 4326 for all my layers and
> not the layers source system 32648.
> This is a part from the capabilities upload summary in mapbender. maybe
> thats the problem but i don't know how and where i can fix it:
> gui_wms_epsg: EPSG:4326
> wms_srs: EPSG:32648
> greets christian
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
INTERGEO 2011
27.-29. September 2011 in Nürnberg
Treffen Sie die WhereGroup in Halle 7, Stand E75
www.intergeo.de
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
 http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
 pgp-public key:
 http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
  Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users mailing list
