[Mapbender-users] Re: SwitchLocale noreload works only after reload
Albert Polze A.Polze at mailbox.tu-berlin.de
Tue Sep 13 08:19:35 EDT 2011
Hello Astrid,
I'm glad that i could help, but i have to point out that  does the same like
refreshing the page (button F5). So everything a user did  (zooming,
panning, switch layer off/on, change projection etc.) in the application is
revoked and the application is set to the point where the user first opened
it.
In the and my workaround changes the modul "SwitchLocale noreload" into a
""SwitchLocale reload" maybe its just the same like the deprecated module
"switchLocale".
I'm trying to learn some javascript in the moment, if I find a better
solution i will let you know.
Albert
Astrid Emde (WhereGroup) wrote:
> Hi Albert,
> thanks for the bug fix. I noticed the problem too, but did not put effort
> into it to solve it.
> I will fix your recommendation in the Mapbender code and it will be
> available through svn and in Mapbender 2.7.3
> Thanks Astrid
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SwitchLocale-noreload-works-only-after-reload-tp6741515p6787239.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users mailing list
