[Mapbender-users] RE: No maps shown when GUI is opened from outside Intranet
Albert Polze A.Polze at mailbox.tu-berlin.de
Thu Sep 15 10:59:57 EDT 2011
Thanks for your mail Frank, but I was on my way home already.
The "wms-inspector" shows me the same information as when I access the
application via Intranet. Everything rigth from this point of view.
I used the metadata-button, mapbender Metadata webpage shows up, used the
link from request mapframe table and  "*Firefox can't establish a connection
to the server *" appears after some time (nearly 10 min)
I didn't get the capabilities via "WMS-Inspector" either be cause of
"Connection error: Server not found"
So it seems that it is a connection problem. Be cause raster and vector data
are not shown I don't think it is a problem of filesize. But to be sure I
turned the raster layer off via "WMS Anwednungseinstellung", the problem
stays the same.
I tried to access the geoserver administration page and was unsuccessfully.
I think I should look into this direction.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/No-maps-shown-when-GUI-is-opened-from-outside-Intranet-tp6796426p6797213.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users mailing list
