[Mapbender-users] Unable to upload Capabilities (WMS/WFS)
Armin Retterath
armin.retterath at lvermgeo.rlp.de
Tue Dec 18 08:03:21 PST 2012
hello matthias,
your connection part of the mapbender.conf should read like the
following (if you use curl connection and no proxy - what i suggest. if
you use a proxy please set the proxy parameters):
# type of server-connection
# curl, socket, http
define("CONNECTION", "curl");
#define("CONNECTION", "http");
#define("CONNECTION", "socket");
#define("CONNECTION_PROXY", "xx.x.xxx.xx"); // ip
#define("CONNECTION_PORT", "xxxx"); // port
define("CONNECTION_PROXY", ""); // ip
define("CONNECTION_PORT", ""); // port
define("CONNECTION_USER", ""); // user
define("CONNECTION_PASSWORD", ""); // password
define("CONNECTION_USERAGENT", "GeoPortal Rheinland-Pfalz");
# HOSTs not for Proxy (curl)
define("NOT_PROXY_HOSTS", "localhost,127.0.0.1");
we use this configuration for over 6 years (since mb 2.4.1) without any
problems.
if you have further questions - don't hesitate to ask ;-)
regards
armin
On 18.12.2012 16:34, Matthias Uhler wrote:
> Hello mapbender friends,
> trying to upload any kind of Capabilities from LANIS OGC Services
> (http://map1.naturschutz.rlp.de/service_lanis/mod_wms/wms_list.php)
> into my Mapbener 2.7.2 installation causes following problem:
> file:
> http://map1.naturschutz.rlp.de/service_lanis/mod_wms/wms_getmap.php?mapfile=naturpark&service=WMS&version=1.1.1&Request=GetCapabilities
> Missing parameters:
> id:
> version:
> title:
> abstract:
> maprequest:
> capabilitiesrequest:
> featureinforequest:
> gui_wms_mapformat:
> gui_wms_featureinfoformat:
> gui_wms_exceptionformat:
> gui_wms_epsg:
> wms_srs:
> gui_wms_visible:
> gui_wms_opacity:
> support_sld:
> wms Object ( [lastURL] => [wms_id] => [wms_status] => [wms_version] =>
> [wms_title] => [wms_abstract] => [wms_getcapabilities] =>
> [wms_getcapabilities_doc] => [wms_getmap] => [wms_getfeatureinfo] =>
> [wms_getlegendurl] => [wms_upload_url] => [wms_timestamp] =>
> [wms_timestamp_create] => [wms_srs] => Array ( ) [wms_termsofuse] =>
> [fees] => [accessconstraints] => [contactperson] => [contactposition]
> => [contactorganization] => [address] => [city] => [stateorprovince]
> => [postcode] => [country] => [contactvoicetelephone] =>
> [contactfacsimiletelephone] => [contactelectronicmailaddress] =>
> [wms_keyword] => Array ( ) [data_type] => Array ( ) [data_format] =>
> Array ( ) [objLayer] => Array ( ) [wms_supportsld] => [wms_userlayer]
> => [wms_userstyle] => [wms_remotewfs] => [gui_wms_mapformat] =>
> [gui_wms_featureinfoformat] => [gui_wms_exceptionformat] =>
> [gui_wms_epsg] => [gui_wms_sldurl] => [default_epsg] => 0 [overwrite]
> => 1 )
> Data not committed
> In my error.log of the mapbender folder I can find following lines:
> 2012.12.18, 15:06:32,Notice: class_connector: load url:
> 2012.12.18, 15:06:32,Notice: connector: curl without auth
> 2012.12.18, 15:06:32,Notice: class_connector.php:
> NOT_PROXY_HOSTS:<ip>,<ip>,<ip>
> 2012.12.18, 15:06:32,Notice: class_connector.php: http_proxy is not
> set as env variable!
> 2012.12.18, 15:06:32,Notice: class_connector.php: Proxy will not be used!
> 2012.12.18, 15:06:32,Notice: class_connector.php: CURL connect to:
> 2012.12.18, 15:06:52,Notice: class_connector.php: CURL give back:
> 2012.12.18, 15:06:52,ERROR: connector: unable to load:
> The same error also occurs with other services so I think the problem
> is my connector or mapbender setup. Already configured Services are
> working and I'm able to upload and update existing capabilities
> without any trouble.
> Can anyone give me a hint how to solve my problem or what to look for?
> I appreciate your help, thx in advance,
> Matthias
> Matthias Uhler, M.Sc.
> i3mainz - Institut für Raumbezogene Informations- und Messtechnik
> Fachhochschule Mainz, Lucy-Hillebrand-Strasse 2, D-55128 Mainz
> Tel: +49 6131 628 1481
> Fax: +49 6131 628 91481
> matthias.uhler at geoinform.fh-mainz.de
> www.i3mainz.fh-mainz.de
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
0261/492-466
http://www.geoportal.rlp.de
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20121218/45f80f39/attachment.html>
More information about the Mapbender_users
