[Mapbender-users] Unable to upload Capabilities (WMS/WFS)
Matthias Uhler matthias.uhler at geoinform.fh-mainz.de
Tue Dec 18 07:34:46 PST 2012
Hello mapbender friends,
trying to upload any kind of Capabilities from LANIS OGC Services
(http://map1.naturschutz.rlp.de/service_lanis/mod_wms/wms_list.php) into
my Mapbener 2.7.2 installation causes following problem:
file:
http://map1.naturschutz.rlp.de/service_lanis/mod_wms/wms_getmap.php?mapfile=naturpark&service=WMS&version=1.1.1&Request=GetCapabilities
Missing parameters:
id:
version:
title:
abstract:
maprequest:
capabilitiesrequest:
featureinforequest:
gui_wms_mapformat:
gui_wms_featureinfoformat:
gui_wms_exceptionformat:
gui_wms_epsg:
wms_srs:
gui_wms_visible:
gui_wms_opacity:
support_sld:
wms Object ( [lastURL] => [wms_id] => [wms_status] => [wms_version] =>
[wms_title] => [wms_abstract] => [wms_getcapabilities] =>
[wms_getcapabilities_doc] => [wms_getmap] => [wms_getfeatureinfo] =>
[wms_getlegendurl] => [wms_upload_url] => [wms_timestamp] =>
[wms_timestamp_create] => [wms_srs] => Array ( ) [wms_termsofuse] =>
[fees] => [accessconstraints] => [contactperson] => [contactposition] =>
[contactorganization] => [address] => [city] => [stateorprovince] =>
[postcode] => [country] => [contactvoicetelephone] =>
[contactfacsimiletelephone] => [contactelectronicmailaddress] =>
[wms_keyword] => Array ( ) [data_type] => Array ( ) [data_format] =>
Array ( ) [objLayer] => Array ( ) [wms_supportsld] => [wms_userlayer] =>
[wms_userstyle] => [wms_remotewfs] => [gui_wms_mapformat] =>
[gui_wms_featureinfoformat] => [gui_wms_exceptionformat] =>
[gui_wms_epsg] => [gui_wms_sldurl] => [default_epsg] => 0 [overwrite] =>
1 )
Data not committed
In my error.log of the mapbender folder I can find following lines:
2012.12.18, 15:06:32,Notice: class_connector: load url:
2012.12.18, 15:06:32,Notice: connector: curl without auth
2012.12.18, 15:06:32,Notice: class_connector.php:
NOT_PROXY_HOSTS:<ip>,<ip>,<ip>
2012.12.18, 15:06:32,Notice: class_connector.php: http_proxy is not set
as env variable!
2012.12.18, 15:06:32,Notice: class_connector.php: Proxy will not be used!
2012.12.18, 15:06:32,Notice: class_connector.php: CURL connect to:
2012.12.18, 15:06:52,Notice: class_connector.php: CURL give back:
2012.12.18, 15:06:52,ERROR: connector: unable to load:
The same error also occurs with other services so I think the problem is
my connector or mapbender setup. Already configured Services are working
and I'm able to upload and update existing capabilities without any trouble.
Can anyone give me a hint how to solve my problem or what to look for?
I appreciate your help, thx in advance,
Matthias
Matthias Uhler, M.Sc.
i3mainz - Institut für Raumbezogene Informations- und Messtechnik
Fachhochschule Mainz, Lucy-Hillebrand-Strasse 2, D-55128 Mainz
Tel: +49 6131 628 1481
Fax: +49 6131 628 91481
www.i3mainz.fh-mainz.de
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20121218/b7d25fe7/attachment.html>
More information about the Mapbender_users mailing list
