[Mapbender-users] Printing 288dpi Raster layers problem [Antwort]
andreas.hundertmark at lecos-gmbh.de
Thu Feb 2 03:55:47 EST 2012
Hallo David,
Have a look at the logfiles in ...mapbender/log - Folder. Is there any
entry in the error - log?
In the variables from printPDF you can set logRequests to true and then
you will get an entry in the acces - logfile.
With copy and paste open the request in a Browser und you could see the
output from the mapserver.
I think the version 3.0 from the mapserver ist old. I use the version 6.
so I can use the debug - function from the mapserver.
Mit freundlichen Grüßen
Andreas Hundertmark
www.lecos-gmbh.de
Von:
daveyclark <dclark at tayside-vjb.gov.uk>
An:
Mapbender_users at lists.osgeo.org
Datum:
01.02.2012 15:27
Betreff:
Gesendet von:
mapbender_users-bounces at lists.osgeo.org
Hi
I am having problems printing with my mapbender/mapserver GIS application.
I
am using Mapbender version 2.7 and mapserver 3.0. I am using the PDF print
in mapbender when you select print and then a new window comes up which
says
Download: Map as PDF... and then a pdf comes up when you click the link.
Printing vector and raster in 72dpi works fine. However, printing in
288dpi
I am having trouble with. Firstly, I couldn't print anything in 288dpi.
Now,
I am able to print vector layers fine as I have increased the maxsize in
the
mapfile. However, I am unable to print raster layers in 288dpi, all that I
am getting in my pdf is my boundary lines, which are a vector layer over
my
raster tif. As I said, if i print the same raster in 72dpi, I get the
raster
with the boundary lines aswell in the pdf output.
I am thinking it may be something to do with image types. I have
"IMAGETYPE
png24" defined in my wms.map and also my Metadata "wms_format"
"image/gif",
in the wms.map.
When, in mapbender, I do my update wms, I get the following info:
id:
version: 1.1.1
title: *** WMS Server
abstract: This server was setup by **** and is powered by MapServer.
maprequest:
http://****/cgi-bin/mapserv.exe?MAP=p:/ms4w/apps/tutorial/htdocs/wms.map&
capabilitiesrequest:
featureinforequest:
gui_wms_mapformat: image/png
gui_wms_featureinfoformat: text/html
gui_wms_exceptionformat: application/vnd.ogc.se_inimage
gui_wms_epsg: EPSG:27700
wms_srs: EPSG:27700
gui_wms_visible: 1
gui_wms_opacity: 100
support_sld: 1
map -> image/tiff
map -> image/gif
map -> image/png
map -> image/png; mode=24bit
map -> image/jpeg
map -> image/vnd.wap.wbmp
map -> image/svg+xml
featureinfo -> text/plain
featureinfo -> text/html
featureinfo -> application/vnd.ogc.gml
exception -> application/vnd.ogc.se_xml
exception -> application/vnd.ogc.se_inimage
exception -> application/vnd.ogc.se_blank
To me, this looks like it should be able to handle any kind of raster
layer.
Is the problem that my raster's are tif's and i have IMAGETYPE png24 and a
"wms format" "image/gif" defined at the top of my wms.map file? Also,
where
are these image types defined that appear when I update my wms.map? Do I
perhaps need an OUTPUTFORMAT defined in the mapfile? or is this defined
elsewhere?
Any help would be very much appreciated.
Many Thanks
David Clark
View this message in context:
http://osgeo-org.1560.n6.nabble.com/Printing-288dpi-Raster-layers-problem-tp4356479p4356479.html
Sent from the mapbender-users mailing list archive at Nabble.com.
Mapbender_users mailing list
http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20120202/22942810/attachment.html
More information about the Mapbender_users
