[Mapbender-users] Printing 288dpi Raster layers problem [Antwort]
Astrid Emde astrid.emde at wheregroup.com
Thu Feb 2 04:50:28 EST 2012
Hello,
please set $unlink = false; in printPDF.conf (or printPDF_b.conf - when
you use print with button). This will save the images from the WMS in your
tmp folder. You can check whether the images are created.
Set $log = true; and you will get the Map-requests in the mapbender table
mb_log.
Also check in your php.ini the parameter. You may have to increase them:
max_execution_time
max_input_time
memory_limit
Astrid
On Thu, February 2, 2012 8:55 am, andreas.hundertmark at lecos-gmbh.de wrote:
> Hallo David,
> Have a look at the logfiles in ...mapbender/log - Folder. Is there any
> entry in the error - log?
> In the variables from printPDF you can set logRequests to true and then
> you will get an entry in the acces - logfile. With copy and paste open the
> request in a Browser und you could see the output from the mapserver.
> I think the version 3.0 from the mapserver ist old. I use the version 6.
> so I can use the debug - function from the mapserver.
> Mit freundlichen Grüßen
> Andreas Hundertmark
> www.lecos-gmbh.de
> Von:
> daveyclark <dclark at tayside-vjb.gov.uk> An:
> Mapbender_users at lists.osgeo.org
> Datum:
> 01.02.2012 15:27
> Betreff:
> Gesendet von:
> mapbender_users-bounces at lists.osgeo.org
> Hi
> I am having problems printing with my mapbender/mapserver GIS
> application. I
> am using Mapbender version 2.7 and mapserver 3.0. I am using the PDF print
>  in mapbender when you select print and then a new window comes up which
> says Download: Map as PDF... and then a pdf comes up when you click the
> link.
> Printing vector and raster in 72dpi works fine. However, printing in
> 288dpi
> I am having trouble with. Firstly, I couldn't print anything in 288dpi.
> Now,
> I am able to print vector layers fine as I have increased the maxsize in
> the mapfile. However, I am unable to print raster layers in 288dpi, all
> that I am getting in my pdf is my boundary lines, which are a vector layer
> over my raster tif. As I said, if i print the same raster in 72dpi, I get
> the raster with the boundary lines aswell in the pdf output.
> I am thinking it may be something to do with image types. I have
> "IMAGETYPE
> png24" defined in my wms.map and also my Metadata "wms_format" "image/gif",
>  in the wms.map.
> When, in mapbender, I do my update wms, I get the following info:
> id:
> version: 1.1.1
> title: *** WMS Server
> abstract: This server was setup by **** and is powered by MapServer.
> maprequest:
> http://****/cgi-bin/mapserv.exe?MAP=p:/ms4w/apps/tutorial/htdocs/wms.map&
> capabilitiesrequest:
> featureinforequest:
> gui_wms_mapformat: image/png
> gui_wms_featureinfoformat: text/html
> gui_wms_exceptionformat: application/vnd.ogc.se_inimage
> gui_wms_epsg: EPSG:27700
> wms_srs: EPSG:27700
> gui_wms_visible: 1
> gui_wms_opacity: 100
> support_sld: 1
> map -> image/tiff map -> image/gif map -> image/png map -> image/png;
> mode=24bit map -> image/jpeg map -> image/vnd.wap.wbmp map -> image/svg+xml
> featureinfo -> text/plain featureinfo -> text/html featureinfo ->
> application/vnd.ogc.gml exception -> application/vnd.ogc.se_xml exception
> -> application/vnd.ogc.se_inimage
> exception -> application/vnd.ogc.se_blank
> To me, this looks like it should be able to handle any kind of raster
> layer. Is the problem that my raster's are tif's and i have IMAGETYPE png24
> and a "wms format" "image/gif" defined at the top of my wms.map file?
> Also,
> where are these image types defined that appear when I update my wms.map?
> Do I
> perhaps need an OUTPUTFORMAT defined in the mapfile? or is this defined
> elsewhere?
> Any help would be very much appreciated.
> Many Thanks
> David Clark
> http://osgeo-org.1560.n6.nabble.com/Printing-288dpi-Raster-layers-problem-
> tp4356479p4356479.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Astrid Emde
FOSSGIS Konferenz 2012
20.-22. März 2012 in Dessau
http://www.fossgis.de/konferenz/2012
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
 http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
 pgp-public key:
 http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
  Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users mailing list
