[Mapbender-users] Problem to load wms into mapbender
Astrid Emde
astrid.emde at wheregroup.com
Tue Jul 10 03:45:46 PDT 2012
this bug on OSGeo-live was discovered before.
We opened a ticket at:
https://trac.osgeo.org/osgeo/ticket/871
Looks like Mapbender can't handle all the mass of EPSG-Codes GeoServer
adds to the Capabilites-document.
A solution could be to reduce the list of epsg-Codes in Geoserver:
In GeoServer go to Services - WMS and add your preferd EPSG-Codes to
the limited SRS list:
could look like: 4326,31467,31468,31466,25832
Then try to load the WMS in Mapbender again.
I try to fix this bug ini the next OSGeo-Live Version. Mapbender 2.7.3
can handle the big list of EPSG-codes now. This Mapbender version will
be on OSGeo-Live 6.0
Hope this helps
Astrid
Am 10.07.2012 12:02, schrieb Thomas Baschetti:
> Hi,
> falls Deutsch besser geht ist das hier auch erlaubt ;-)
> Funktioniert der Mapbender denn sonst vernünftig? Lassen sich andere WMS-Dienste einladen
> oder ist das ein generelles Problem?
> Was passiert, wenn Du die Capabilites im Browser abfragst, was kommt da als Antwort?
> Es könnte sich auch um ein ähnliches Problem wie hier handeln:
> http://lists.osgeo.org/pipermail/mapbender_users/2012-February/004089.html
> Thomas
> Am 10.07.2012 11:33, schrieb Spacebernsen:
>> Hello,
>> at first sorry for my very bad english. I hope you can understand me.
>> I have the OSgeo Live CD version 5.5. I have installing the programs on a
>> virtual machine. erverything is run and it's looks very fine.
>> But i have a big Problem to load a wms from geoserver into mapbender. when i
>> return my Capabilities request
>> (http://localhost:8082/geoserver/tiger/wms?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1)
>> I become the following answer:
>> file:
>> I think that other peoples have the same problem but i don't can find every
>> think on the internet.
>> thank you for your help (and once more sorry for my bad english)
>> View this message in context: http://osgeo-org.1560.n6.nabble.com/Problem-to-load-wms-into-mapbender-tp4987179.html
>> Sent from the mapbender-users mailing list archive at Nabble.com.
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users
