[Mapbender-users] Load WMS Error
Ramesh De Silva
desilvarami at gmail.com
Wed Jul 25 20:29:13 PDT 2012
When I try to Load a new WMS ( which is running in the same machine) using
the "Load WMS" option provided in admin interface; I come across the
following error message. I use Mapbender version 2.7.3.
*file: http://***.***.***.192/cgi-bin/mapserv.exe?map=/ms4w/apps/srilanka/sl.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0sql
error: ERROR: unnamed prepared statement does not exist ROLLBACK
performed....*
But if I try to load the same WMS temporary using the "Adding WMS" option
in GUI Template Application; it works fine. Assuming it is a database
error; I tried with different versions of PostgreSQL ( V 8.2 and 9.1.4);
but the result was the same.
Also if I use an older Mapbender version ( V 2.4) the WMS loads permanently
without any error.
Please provide me any possible solution for this issue.
Thank you.
Cheers
Ramesh
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20120726/d3a794be/attachment.html>
More information about the Mapbender_users
