[Mapbender-users] install difficulties
chris Wild
chrismwild at gmail.com
Wed Mar 28 17:23:19 EDT 2012
Hi Thomas and Verena,
Thanks for your replies most appreciated.
As you suggested Thomas, I think the problem is with PHP so
I added
## PHP 5 CGI config
AddType application/x-httpd-php .php5 .php4 .php3 .phtml .php
Action application/x-httpd-php /cgi-bin/php-cgi.exe
into the Apache httpd.conf
The request to localhost then returned this error.
*The requested URL /cgi-bin/php-cgi.exe/mapbender/tools/mapbender_setup.php
was not found on this server*.
So I copied php-cgi.exe to C:\Program Files\Apache Group\Apache2\cgi-bin
Message then
Fatal error: Call to undefined function pg_connect() in C:\Program
Files\mapbender_2.7.2\mapbender\lib\database-pgsql.php on line 9*7
Not sure what to do now. The database setup in the Mapbender install seemed
to go OK.
Thanks for the tip re maptools/ms4w. I have not used Mapserver before
rather Geoserver so was thinking of sticking with that.
Kind regards
Chris
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20120329/f2f60faf/attachment.html
More information about the Mapbender_users
