[Mapbender-users] Re: install difficulties
Thomas Baschetti
info at thomas-baschetti.de
Wed Mar 28 17:42:00 EDT 2012
Am 28.03.2012 23:23, schrieb chris Wild:
> Message then
> Fatal error: Call to undefined function pg_connect() in C:\Program Files\mapbender_2.7.2\mapbender\lib\database-pgsql.php on line 9*7
> Not sure what to do now. The database setup in the Mapbender install seemed to go OK.
you need to enable the correct php-modules in your php.ini, in this case php5-pgsql (and others!)
Please read and follow the guides in
http://www.mapbender.org/Installation_en
and
http://www.mapbender.org/Manual_Installation#PHP_Configuration_PHP_configuration
There are several steps you have to follow to get everything running.
Or try the Osgeo-live http://live.osgeo.org/ which has a running version of mapbender in an ubuntu environment. Works from DVD, USB-Drive or Virtual Machine (e.g.
Virtualbox, vmware...)
Thomas
Thomas Baschetti - Systemanalyse Geographische Informationssysteme
Hakenstraße 8D
49074 Osnabrück
Tel: 0541 25 91 90 | mobil 01577 189 25 91
E-Mail: info at thomas-baschetti.de
www.thomas-baschetti.de
Ust-IdNr.: DE264355072
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20120328/a6e9b53b/attachment.html
More information about the Mapbender_users
