[Mapbender-users] Projection to DHDN3 GK Zone3 EPSG:31467
Leukert, Boris boris.leukert at wald-und-holz.nrw.de
Tue Sep 18 07:37:56 PDT 2012
We do it the other way around (31467 to 25832) and it works with the projection settings I send you.
What is the data source of the alkis-data-wms (Shapefile / PostGIS etc.)?
Boris
-----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von a.borgardt at landkreis-cuxhaven.de
Gesendet: Dienstag, 18. September 2012 16:29
An: mapbender_users at lists.osgeo.org
Betreff: Re: [Mapbender-users] Projection to DHDN3 GK Zone3 EPSG:31467
I try to project alkis-data-wms with an initial projection ETRS89/UTM32N epsg:25832 to epsg:31467. As reference test data I use an alk-shape with epsg:31467.
> -----Original Message-----
> From: Leukert, Boris [mailto:boris.leukert at wald-und-holz.nrw.de]
> Sent: Tuesday, September 18, 2012 4:16 PM
> To: Mapbender User List
> Subject: Re: [Mapbender-users] Projection to DHDN3 GK Zone3 EPSG:31467
> From which projection system do you try to reproject to EPSG:31467?
> Do you have some test data?
> Boris
> Gesendet: Dienstag, 18. September 2012 16:11
> Hi Boris,
> it works. A "little" sign in the epsg-file...but I've still
> the same offset in the coordinates after the projection.
> Thank you very much for your help.
> Andreas
> > Sent: Tuesday, September 18, 2012 3:25 PM
> EPSG:31467
> > Hi Andreas,
> > can you check the entry in the epsg file (or revert back to the old
> > entry)?
> > The QGis error message sound like there is a syntax problem in the
> > file.
> > Boris
> > Gesendet: Dienstag, 18. September 2012 14:51
> EPSG:31467
> >  Moin Boris,
> > after applying the suggested changes, Q-GIS reports the following
> > error:
> > <?xml version='1.0' encoding="UTF-8" standalone="no" ?> <!DOCTYPE
> > ServiceExceptionReport SYSTEM
> > "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
> > <ServiceExceptionReport version="1.1.1"> <ServiceException>
> > msProcessProjection(): Projection library error. unknown
> projection id
> > </ServiceException> </ServiceExceptionReport>
> > I changed the BETA2007.gsb-path to /usr/share/proj/.
> > Andreas
> > > Sent: Tuesday, September 18, 2012 1:50 PM
> > EPSG:31467
> > > Hi Andreas,
> > > I'm using the following entries to reproject from EPSG
> 31467 to UTM
> > > and it works fine:
> > > PROJ.4 epsg file:
> > > <31467> +proj=tmerc +lat_0=0 +lon_0=9 +k=1 +x_0=3500000
> > > +y_0=0 +ellps=bessel +datum=potsdam +units=m +no_defs
> > > +nadgrids=/opt/libproj/share/proj/BETA2007.gsb +wktext  <>
> > > PostGIS table spatial_ref_sys:
> > > UPDATE spatial_ref_sys
> > >    SET proj4text = '+proj=tmerc +lat_0=0 +lon_0=9 +k=1
> > > +x_0=3500000 +y_0=0 +ellps=bessel +datum=potsdam +units=m no_defs
> > > ++nadgrids=/opt/libproj/share/proj/BETA2007.gsb +wktext '
> > >  WHERE srid = 31467;
> > > Please change the directory "/opt/libproj/share/proj/" to the
> > > directory of your installation where the file BETA2007.gsb
> > is located.
> > > Best regards,
> > > Boris
> > >> Gesendet: Dienstag, 18. September 2012 13:20
> > >> Betreff: [Mapbender-users] Projection to DHDN3 GK Zone3
> EPSG:31467
> > >> Hi Mapbenders,
> > >> I'm trying to project a wms with the change epsg button.
> > The function
> > >> works, but the resulting coordinates are not correct.
> They differ
> > >> about 32m to west and about 175m to the south to a "real"
> > dhdn-shape.
> > >> I tried two proj4-parameters in the spatial_ref_sys
> table for epsg
> > >> 31467:
> > >> +proj=tmerc +lat_0=0 +lon_0=9 +k=1.000000 +x_0=3500000 +y_0=0
> proj=tmerc +lat_0=0
> > >> ++lon_0=9 +k=1.000000 +x_0=3500000 +y_0=0 ellps=bessel
> > +datum=potsdam
> > >> ++nadgrids=BeTA2007 +units=m +no_defs
> > >> but nothing changes.
> > >> Thanks for any help!
> > >> Best regards
> > >> Andreas
> > >> Dipl.-Geol. Andreas Borgardt
> > >> Landkreis Cuxhaven
> > >> 06 - GIS-Service
> > >> Tel.: 04721/66 23 68
> > >> E-Mail: a.borgardt at landkreis-cuxhaven.de
> > > _______________________________________________
> > > Mapbender_users mailing list
> > > Mapbender_users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
