[Mapbender-users] Projection to DHDN3 GK Zone3 EPSG:31467
a.borgardt at landkreis-cuxhaven.de
Tue Sep 18 08:05:13 PDT 2012
The ALKIS-Datasource is a PostGIS-DB. I changed proj4text-columnentry in mapbender-db and alkisdata-db. The mabender-conf-file contains an entry for EPSG:31467 as srs-array. In a second step adding "nadgrids=/usr/share/proj/BETA2007.gsb" to the alkis-map-file in the projection section. so far without success...
Andreas
> -----Original Message-----
> From: Leukert, Boris [mailto:boris.leukert at wald-und-holz.nrw.de]
> Sent: Tuesday, September 18, 2012 4:38 PM
> To: Mapbender User List
> Subject: Re: [Mapbender-users] Projection to DHDN3 GK Zone3 EPSG:31467
> We do it the other way around (31467 to 25832) and it works
> with the projection settings I send you.
> What is the data source of the alkis-data-wms (Shapefile /
> PostGIS etc.)?
> Boris
> -----Ursprüngliche Nachricht-----
> Von: mapbender_users-bounces at lists.osgeo.org
> [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
> von a.borgardt at landkreis-cuxhaven.de
> Gesendet: Dienstag, 18. September 2012 16:29
> An: mapbender_users at lists.osgeo.org
> Betreff: Re: [Mapbender-users] Projection to DHDN3 GK Zone3 EPSG:31467
> I try to project alkis-data-wms with an initial projection
> ETRS89/UTM32N epsg:25832 to epsg:31467. As reference test
> data I use an alk-shape with epsg:31467.
> > Sent: Tuesday, September 18, 2012 4:16 PM
> EPSG:31467
> > From which projection system do you try to reproject to EPSG:31467?
> > Do you have some test data?
> > Boris
> > [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von
> > Gesendet: Dienstag, 18. September 2012 16:11
> EPSG:31467
> > Hi Boris,
> > it works. A "little" sign in the epsg-file...but I've still
> the same
> > offset in the coordinates after the projection.
> > Thank you very much for your help.
> > Andreas
> > > Sent: Tuesday, September 18, 2012 3:25 PM
> > EPSG:31467
> > > Hi Andreas,
> > > can you check the entry in the epsg file (or revert back
> to the old
> > > entry)?
> > > The QGis error message sound like there is a syntax
> problem in the
> > > file.
> > > Boris
> > > Gesendet: Dienstag, 18. September 2012 14:51
> > EPSG:31467
> > > Moin Boris,
> > > after applying the suggested changes, Q-GIS reports the following
> > > error:
> > > <?xml version='1.0' encoding="UTF-8" standalone="no" ?> <!DOCTYPE
> > > ServiceExceptionReport SYSTEM
> > > "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
> > > <ServiceExceptionReport version="1.1.1"> <ServiceException>
> > > msProcessProjection(): Projection library error. unknown
> > projection id
> > > </ServiceException> </ServiceExceptionReport>
> > > I changed the BETA2007.gsb-path to /usr/share/proj/.
> > > Andreas
> > > > Sent: Tuesday, September 18, 2012 1:50 PM
> > > EPSG:31467
> > > > Hi Andreas,
> > > > I'm using the following entries to reproject from EPSG
> > 31467 to UTM
> > > > and it works fine:
> > > > PROJ.4 epsg file:
> > > > <31467> +proj=tmerc +lat_0=0 +lon_0=9 +k=1 +x_0=3500000
> > > > +y_0=0 +ellps=bessel +datum=potsdam +units=m +no_defs
> > > > +nadgrids=/opt/libproj/share/proj/BETA2007.gsb +wktext <>
> > > > PostGIS table spatial_ref_sys:
> > > > UPDATE spatial_ref_sys
> > > > SET proj4text = '+proj=tmerc +lat_0=0 +lon_0=9 +k=1
> > > > +x_0=3500000 +y_0=0 +ellps=bessel +datum=potsdam
> +units=m no_defs
> > > > ++nadgrids=/opt/libproj/share/proj/BETA2007.gsb +wktext '
> > > > WHERE srid = 31467;
> > > > Please change the directory "/opt/libproj/share/proj/" to the
> > > > directory of your installation where the file BETA2007.gsb
> > > is located.
> > > > Best regards,
> > > > Boris
> Auftrag von
> > > >> Gesendet: Dienstag, 18. September 2012 13:20
> > > >> Betreff: [Mapbender-users] Projection to DHDN3 GK Zone3
> > EPSG:31467
> > > >> Hi Mapbenders,
> > > >> I'm trying to project a wms with the change epsg button.
> > > The function
> > > >> works, but the resulting coordinates are not correct.
> > They differ
> > > >> about 32m to west and about 175m to the south to a "real"
> > > dhdn-shape.
> > > >> I tried two proj4-parameters in the spatial_ref_sys
> > table for epsg
> > > >> 31467:
> > > >> +proj=tmerc +lat_0=0 +lon_0=9 +k=1.000000 +x_0=3500000 +y_0=0
> > proj=tmerc +lat_0=0
> > > >> ++lon_0=9 +k=1.000000 +x_0=3500000 +y_0=0 ellps=bessel
> > > +datum=potsdam
> > > >> ++nadgrids=BeTA2007 +units=m +no_defs
> > > >> but nothing changes.
> > > >> Thanks for any help!
> > > >> Best regards
> > > >> Andreas
> > > >> Dipl.-Geol. Andreas Borgardt
> > > >> Landkreis Cuxhaven
> > > >> 06 - GIS-Service
> > > >> Tel.: 04721/66 23 68
> > > >> E-Mail: a.borgardt at landkreis-cuxhaven.de
> > > > _______________________________________________
> > > > Mapbender_users mailing list
> > > > Mapbender_users at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
