[Mapbender-users] print,
Armin Retterath
armin.retterath at lvermgeo.rlp.de
Tue Sep 25 07:59:27 PDT 2012
hello,
i don't think, that you have to put in s.th. there. normally the
mapbender configuration is defined in mapbender.conf. is there a problem
to load wms into mapbender? which connection do you setup in
mapbender.conf? we use curl, cause it is most flexible. are you work
behind a proxy or only localhost on your desktop pc? which os do you use?
regards
armin
On 25.09.2012 15:24, Spacebernsen wrote:
> Hello everybody,
> i have a problem with the print-modul. I can´t print. When i put the print
> bottom the pdf is white. I think i have found the problem in the php.ini
> from geoserver (link: http://www.mapbender.org/Php.ini#Drucken). But now i
> have a question allmost of the parameters are right but four parameters are
> not in my php.ini. In the script (http://www.mapbender.org/Php.ini#Drucken)
> i read that the parameters
> ; Default proxy IP address (if required).
> pfpro.proxyaddress = "proxy.xxx.yyy.de"
> ; Default proxy port.
> pfpro.proxyport = 8080
> ; Default proxy logon.
> pfpro.proxylogon = "domaene\user"
> ; Default proxy password.
> pfpro.proxypassword = "xxxxxxxx"
> must into the php.ini. But what must I write into the different thinks. is
> proxy my ip-address, what is proxypassword etc.?
> please help me. Thanks for everybody
> View this message in context: http://osgeo-org.1560.n6.nabble.com/print-tp5004269.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
0261/492-466
http://www.geoportal.rlp.de
More information about the Mapbender_users
