[Mapbender-users] Problem with wms in a mapbender copy
Armin Retterath
armin.retterath at gmail.com
Tue Aug 20 13:56:04 PDT 2013
hi Charles,
Sorry i forgot - if you have the postgis 2.0 you need to install the legacy
package First. This package allows the backward compatibility to 1.5 and if
you dont have installed it the mb_metadata table wont be created :-( .
I normaly push All postgis functions into a own Schema and the mapbender
tables into another. The legacy package is a simple SQL which you have to
execute at the database. Dont forget to Set the right search path. I
normally use mapbender,public and the postgis functions are in the public
Schema and the mapbender tables are in a mapbender Schema.
Have a nice evening
I will go to bed now ;-)
Regards FROM Germany
Armin
Am 20.08.2013 21:40 schrieb "Charles Nievas" <cnievas-npm at adinet.com.uy>:
> Thank you Armin, but i think the problem may cause by diferent versions of
> postgis, the original mapbender was installed under postgis 1.5 and the new
> server has postgis 2.0. Iĺl continue trying to solve.
> Thank you very much for your help.
> Regards,
> Charles
> ______________________________**_________________
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.**org <Mapbender_users at lists.osgeo.org>
> http://lists.osgeo.org/**mailman/listinfo/mapbender_**users<http://lists.osgeo.org/mailman/listinfo/mapbender_users>
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20130820/3d4cc109/attachment.html>
More information about the Mapbender_users
