[Mapbender-users] Problem with wms in a mapbender copy
Armin Retterath
armin.retterath at lvermgeo.rlp.de
Tue Aug 20 22:51:36 PDT 2013
hello charles,
the postgis docs give the answer:
you should use the legacy.sql script before importing contents from
databases with postgis 1.x.
some function names have altered and some further things have changed.
http://postgis.net/docs/postgis_installation.html#create_new_db
http://northwestspatial.com/wp/?p=356
regards,
armin
On 20.08.2013 21:40, Charles Nievas wrote:
> Thank you Armin, but i think the problem may cause by diferent
> versions of postgis, the original mapbender was installed under
> postgis 1.5 and the new server has postgis 2.0. Iĺl continue trying to
> solve.
> Thank you very much for your help.
> Regards,
> Charles
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
0261/492-466
http://www.geoportal.rlp.de
More information about the Mapbender_users
