[Mapbender-users] Load WMS issue
Ramesh De Silva desilvarami at gmail.com
Wed Jan 23 00:00:06 PST 2013
Hello Armin,
Thanks a lot for the reply.
I am inside a university network but proxy settings are unknown to the
users. We set "automatically detect Proxy" in browser settings. May be I
can request proxy information from university network administration and
try to provide values in the mapbender.conf.
But my worry is; with the WMS running in localhost also I get this issue. I
have set NOT_PROXY_HOSTS as follows
*define("NOT_PROXY_HOSTS", "localhost");*
By the way I am running everything on Windows 2003 Server.
The imagick extension is not enabled in php.ini yet. Does it have any
impact for this? Actually I disabled it as I couldn't start Apache after
enabling this extension.
Thank you.
Best Regards
Ramesh
On Wed, Jan 23, 2013 at 2:01 PM, Armin Retterath <
armin.retterath at lvermgeo.rlp.de> wrote:
>  Hello Ramesh,
> it seems to be a http connection problem. Do you work behind a proxy? You
> have to define the proxy variables in the conf/mapbender.conf file.
> I recommend to use the connection via curl library. It is very good in
> most environments.
> Do you use mapbender under windows or linux?
> If you don't have a proxy test the following configuration:
> define("CONNECTION", "curl");
> #define("CONNECTION", "http");
> #define("CONNECTION", "socket");
> #define("CONNECTION_PROXY", "xxxx"); // ip
> #define("CONNECTION_PORT", "xxxx"); // port
> define("CONNECTION_PROXY", ""); // ip
> define("CONNECTION_PORT", ""); // port
> define("CONNECTION_USER", ""); // user
> define("CONNECTION_PASSWORD", ""); // password
> define("CONNECTION_USERAGENT", "Mapbender");
> (libcurl and php5-curl is needed)
> Regards
> Armin
> On 23.01.2013 07:38, Ramesh De Silva wrote:
> Hello,
> I have a problem in loading any WMS to Mapbender. When I try to load a WMS
> using a WMS Capabilities URL; nothing happens. It shows me the WMS
> Capabilities URL itself in the resulting screen.
> The WMS Capabilities URLs I used as follows
> *From Localhost:*
> http://localhost:8080/geoserver/GIC/wms?service=WMS&version=1.1.0&request=GetCapabilities
> *Then from other WMS sources
> *Cadastre of spain*
> http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx?VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS
> *Bird Studies Canada*
> http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS
> <http://www.bsc-eoc.org/cgi-bin/bsc_ows.asp?VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS>
> I am running Geoserver version 2.2.1 and Mapbender 2.7.3 in my machine.
> The default maps provided in Mapbender are working fine.
> Really appreciate any help to resolve this problem.
> Thank you.
> Best regards
> Ramesh
> Mapbender_users mailing listMapbender_users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapbender_users
> Zentrale Stelle Geodateninfrastruktur
> Rheinland-Pfalz
> LVermGeo-RP
> Ferdinand-Sauerbruch-Straße 15
> 56073 Koblenz
> 0261/492-466armin.retterath at lvermgeo.rlp.dehttp://www.geoportal.rlp.de
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20130123/bffe50b0/attachment-0001.html>
More information about the Mapbender_users mailing list
