[Mapbender-users] HQ-Print vs. OWSPROXY
Jäger, Frank (KRZ)
F.Jaeger at KRZ.DE
Wed Mar 20 08:23:39 PDT 2013
Hallo Armin,
> do you use rewrite or redirect?
I think "Rewrite", defined in "/etc/apache2/httpd.conf":
Alias /mbneu/owsproxy/ "/opt/gdi/mbneu/owsproxy/"
<Directory /opt/gdi/mbneu/owsproxy/>
Options +FollowSymLinks
ReWriteEngine On
RewriteBase /owsproxy
RewriteRule ^([\w\d]+)\/([\w\d]+)\/?$ http://127.0.0.1/mbneu/owsproxy/http/index.php?sid=$1\&wms=$2\& [P,L,QSA,NE]
Options +Indexes
Allow from all
</Directory>
> do you used the new define options
Not yet .
In progress ...
> please have a look at trunk
What is the difference between "branches/2.7" and "trunk" ?
I wanted to get the fast-loading-GUIs-from-cache in my testing-Instance of Mapbender ("mbneu"). This works since ~ October.
Yesterday I first updated my "mbneu" from "trunk" and it doesn't work.
Then I updated from "branches/2.7" and get the fast loading GUIs.
Hmmm .. can I mix the scripts from 2.7 with the .conf from trunk?
I hope that MB 2.7.4 will be released soon. I like to begin testing already before the release.
Which branch is nearest to the code that will be released? Which is more stable?
My test is "Upgrdating a production-configuration from 2.7.3 to 2.7.4".
I think this will grab more conflicts the a fresh configured Developer-Version with "Germany-Demo" an "Mapbender-Users".
Frank
-----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Armin Retterath
Gesendet: Mittwoch, 20. März 2013 15:36
An: Mapbender User List
Betreff: Re: [Mapbender-users] HQ-Print vs. OWSPROXY
hi frank,
maybe i can help you next week?
do you used the new define options of the mapbender.conf-dist - please have a look at trunk - do you use rewrite or redirect?
armin
2013/3/20 Jäger, Frank (KRZ) <F.Jaeger at krz.de>:
> Hallo,
> is there a conflict between OWSPROXY and the classic HQ-Print-Method
> - 288 dpi
> - *_4.map-Files
> - listed in /http/print/printPDF.conf: $highqualitymapfiles = array(
> I'm testing with MB 2.7.3+ from actual SVN branch/2.7 and don't get a HQ-Print for WMS with OWSPROXY switched ON.
> Frank
More information about the Mapbender_users
