[Mapbender-users] HQ-Print vs. OWSPROXY
Armin Retterath
armin.retterath at gmail.com
Wed Mar 20 08:45:58 PDT 2013
hello frank,
i think the code doesn't differ as much. in trunk there are more new
functions. we will merge both code before releasing 2.7.4 i think. i
think also, that we forgot the caching of the guis in trunk, this was
only done in branch.
mod rewrite is good. the owsproxy now needs more functions and
therefor mod rewrite is needed. there were some big security risks in
older module.
i am back in office on monday. maybe i then can have a closer look.
(we use trunk on our production system - http://www.geoportal.rlp.de ;-) )
regards
armin
2013/3/20 Jäger, Frank (KRZ) <F.Jaeger at krz.de>:
> Hallo Armin,
>> do you use rewrite or redirect?
> I think "Rewrite", defined in "/etc/apache2/httpd.conf":
> Alias /mbneu/owsproxy/ "/opt/gdi/mbneu/owsproxy/"
> <Directory /opt/gdi/mbneu/owsproxy/>
> Options +FollowSymLinks
> ReWriteEngine On
> RewriteBase /owsproxy
> RewriteRule ^([\w\d]+)\/([\w\d]+)\/?$ http://127.0.0.1/mbneu/owsproxy/http/index.php?sid=$1\&wms=$2\& [P,L,QSA,NE]
> Options +Indexes
> Allow from all
> </Directory>
>> do you used the new define options
> Not yet .
> In progress ...
>> please have a look at trunk
> What is the difference between "branches/2.7" and "trunk" ?
> I wanted to get the fast-loading-GUIs-from-cache in my testing-Instance of Mapbender ("mbneu"). This works since ~ October.
> Yesterday I first updated my "mbneu" from "trunk" and it doesn't work.
> Then I updated from "branches/2.7" and get the fast loading GUIs.
> Hmmm .. can I mix the scripts from 2.7 with the .conf from trunk?
> I hope that MB 2.7.4 will be released soon. I like to begin testing already before the release.
> Which branch is nearest to the code that will be released? Which is more stable?
> My test is "Upgrdating a production-configuration from 2.7.3 to 2.7.4".
> I think this will grab more conflicts the a fresh configured Developer-Version with "Germany-Demo" an "Mapbender-Users".
> Frank
> -----Ursprüngliche Nachricht-----
> Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Armin Retterath
> Gesendet: Mittwoch, 20. März 2013 15:36
> An: Mapbender User List
> Betreff: Re: [Mapbender-users] HQ-Print vs. OWSPROXY
> hi frank,
> maybe i can help you next week?
> do you used the new define options of the mapbender.conf-dist - please have a look at trunk - do you use rewrite or redirect?
> armin
>> Hallo,
>> is there a conflict between OWSPROXY and the classic HQ-Print-Method
>> - 288 dpi
>> - *_4.map-Files
>> - listed in /http/print/printPDF.conf: $highqualitymapfiles = array(
>> I'm testing with MB 2.7.3+ from actual SVN branch/2.7 and don't get a HQ-Print for WMS with OWSPROXY switched ON.
>> Frank
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
