[Mapbender-users] Logo-problem solved
Astrid Emde
astrid.emde at wheregroup.com
Fri Jan 31 02:25:42 PST 2014
Am 31.01.2014 11:09, schrieb richard_struggle:
> Hello to everybody,
> I finally solved the logo-problem. I deleted the Mapbender3-files completely
> and then installed the mapbender3-starter-develop-3.0.1build236 again. I
> added my template and the logo-image. Then I used a new database, created a
> new application with my template and everything worked fine. After this I
> tried to use my old database with this new Mapbenderinstallation and it
> worked as well. I'm happy about this, because it is not necessary to create
> the applications, I used before, again.
> I'm still wondering why my template worked at the developers mode but not at
> the normal mode. Does anybody have an idea?
> Greetings
> Richard
Hello Richard,
thanks for you feedback and good, that the installation and update works
fine.
When you update to a newer version you have to merge some files, update
the database with
app/console doctrine:schema:update --force
and run
app/console assets:install web (if you do not use symbolic links)
The last command will export files to the web directory which is public.
You also should delete the cache at mapbender3/app/cache/prod (here you find the files when you start app.php) /data/git/mb3/application/app/cache/dev (files from app_dev.php)
Have a look for details in the update description in the documentation at:
http://doc.mapbender3.org/en/book/installation.html#update-mapbender3-to-a-newer-version
Best regards
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users
