[Mapbender-users] Antw: Re: Legend
Gerhard Mocza
gerhard.mocza at boku.ac.at
Fri Dec 11 05:55:21 PST 2015
Hi Astrid !
Thanks for quick response.
First: the connection from the inside-GIS-Server to the world is
unchecked by myself, but it was tested today positive with a friend (in
the outside world).
So it was surprising for me, to put a check to PROXY in the WMS-Instanz
of the service and the connection is working already without
configuration of proxy in parameters.yml.
I am using mapbender 3.0.4.1.
I am sending screenshots of the legend (with proxy: bottleneck1 and
without proxy: bottleneck2) and the log of the apache-access (first 15
lines for application bottleneck1 with proxy checked and spoiled legend,
last line for application bottleneck2 with proxy unchecked and working
legend).
kind regards
Gerhard
Gerhard Mocza
Institut f. Vermessung, Fernerkundung und Landinformation
Peter Jordan Str. 82
A-1190 Wien
Tel.: 47654/5117
email: gerhard.mocza at boku.ac.at>>> Astrid Emde
<astrid.emde at wheregroup.com> 11.12.2015 13:51 >>>
Hallo,
when you print the requests are send from the server. So your server
must reach the services and know himself.
Please configure the proxy in parameters.yml
http://doc.mapbender3.org/en/book/installation/configuration.html#parameters-yml
And maybe define ows_proxy3_noproxy.
Have a look in your logfiles to find out which requests failed and what
is the error message.
Can you send a map and a getLegend request to compare the two?
Do you use Mapbender3 3.0.5.2? We had an issue with the legend in
earlier versions.
Astrid
Am 11.12.2015 12:38, schrieb Gerhard Mocza:
Hi All !
I have already successful installed a mapbender-application, which
request WMS-Services from an Server inside our local net, seperated
through a firewall.
Outside the local net in the DMZ-Zone mapbender is working with
legends, generated from the layers of the wms-service.
Recently i found out, this configuration is working well with the
proxy-function, but legends are not displayed anymore. When i turn off
the proxy-function, inside the local net i can use wms from our
GIS-Server with displayed layers in the legend (of course not outside
the local net) - turning on the proxy-functions will disturb displaying
layers in the legend.
Has anyone seen this too ?
Thanks und regards
Gerhard M
Gerhard Mocza
A-1190 Wien
Tel.: 47654/5117
Mapbender_users mailing
listMapbender_users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
FOSS Academy Winterschule 2016
Alles Wichtige zur Erstellung einer GDI in nur 5
Tagen!http://www.foss-academy.eu/winterschule_2016*********************************************************
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
astrid.emde at wheregroup.com www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20151211/1abfab0b/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20151211/1abfab0b/attachment-0001.obj>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20151211/1abfab0b/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20151211/1abfab0b/attachment-0003.jpg>
More information about the Mapbender_users
