[Mapbender-users] Difficulties installing demo
Astrid Emde astrid.emde at wheregroup.com
Mon Jul 20 05:59:20 PDT 2015
Hello Franklin,
you want  to use PostgreSQL as your database.
Then you have to leave database_path empty like:
database_path:   ~
After this change you should be fine, else please write again.
Best regards
Astrid
Am 20.07.2015 14:50, schrieb Franklin Januario da Silva:
> Good morning gentlemen,
> Sorry for my bad english, I'm trying to run the script to install the
> demonstration bundler but I'm getting an error that appears to be
> linked to the directory path.
> My installation of Mapbender was carried out in the following directory:
> C: \ OSGeo4W \ var \ www \ mapbender3
> Postgis created a database named Mapbender. I configured the
> parameter.yml as follows:
>   database_driver:   pdo_pgsql
>     database_host:     localhost
>     database_port:     5432
>     database_name:     mapbender
>     database_path:     %kernel.root_dir%/db/demo.sqlite
>     database_user:     postgres
>     database_password: dummy
> I think I should change the line "database_path:% kernel.root_dir% /
> db / demo.sqlite" but I'm not sure.
> Running the script below:
> php.exe app / console doctrine: database: create
> I get this:
> An exception occurred while executing 'CREATE DATABASE
> C:\OSGeo4W\var\www\mapbender3\app/db/demo.sqlite':
> SQLSTATE[42601]: Syntax error: 7 ERRO:  erro de sintaxe em ou próximo
> a ":"
> LINE 1: CREATE DATABASE C:\OSGeo4W\var\www\mapbender3\app/db/demo.sq...
> Tanks for help,
> *          Agricola
>           64 3634-2806
>           64 9979-0608
> *          cerradinho.com.br <http://www.cerradinho.com.br>
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
FOSS Academy Sommerschule 2015
Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
http://www.foss-academy.eu/kompaktkurse_sommerschule_2015
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
 Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
 pgp-public key:
 http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
  Signed and/or encrypted mail is highly appreciated
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20150720/2d0eb629/attachment-0001.html>
More information about the Mapbender_users mailing list
