[Mapbender-users] Mapbender3, Error when adding a user
Uwe Seher
uwe.seher at gmail.com
Tue Oct 27 05:19:40 PDT 2015
Hello group!
This i my first post on this list, so first a small introduction. I am a
geologist working in a engineering bureau in Karlsruhe/Germany and the
admin of a small GDI which we use to present geodata to our customers. I
used mapbender 2 for a long time and now i want to switch to mapbender 3. I
installed it for evaluation on my laptop, which worked good (Maybe you can
add the php-openssl package to the prerequisites, there is only openssl
mentioned. I am on opensuse, debian/ubuntu may have no problem with this).
Now the Problem:
When i try to add a new user the following error-message appears:
FatalErrorException: Error: Call to undefined method
Symfony\Component\HttpFoundation\Session\Session::setFlash() in
/srv/www/htdocs/mapbender3-3.0.5.1/fom/src/FOM/UserBundle/Controller/UserController.php
line 175
I have no real experience at this time with symphony/php so i do not know
how to get arround this problem. The standard installation routine
described on
http://doc.mapbender3.org/de/book/installation/installation_ubuntu.html did
work and creating groups and apps is also working fine. Maybe you can give
me a hint where to search.
Thank you in advance
Uwe Seher
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20151027/ff0d6883/attachment.html>
More information about the Mapbender_users
