[Mapbender-users] I can not adjust SearchRouter. Please help
Charlotte Toma
charlotte.toma at wheregroup.com
Thu Dec 1 05:47:15 PST 2016
Hello,
if you have problems with the configuration of the *searchrouter or
digitizer YAML* then you can use this side: /http://www.yamllint.com//
to validate your text.
Can you show us your url? Something like this works:
http://localhost/mapbender3/*app_dev.php* and this doesn't:
http://localhost/mapbender3/*app.php* ? Nothing in the logs?
Mit freundlichen Grüßen
Charlotte Toma
GIS-Consultant
Where2B Konferenz 2016
15. Dezember 2016 in Bonn
www.where2b-conference.com
Charlotte Toma
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 24
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 01.12.2016 um 14:41 schrieb Den:
> Good afternoon!
> At me it turned out to launch SearchRouter. My error consisted in accidental
> use of TAB but not SPASE
> in the config.yml and parameters.yml files. It can't be done categorically.
> I recommend to add it to a manual. The tool earned on Lubuntu OSGeo-Live
> 10.0. On Windows it wasn't succeeded to launch but errors weren't any more.
> Possibly a problem in connection to the database.
> I used the osm_local database and a configuration taken from the
> FOSS4G2016_Mapbender3_Workshop_searchrouter.txt file
> After that everything turned out. Tried to add the data to osm_local basis
> and to look for according to them - also works.
> But I faced a problem - everything works under app_dev. When I try to launch
> through app - No results found.
> As far as I understand here matter in a server configuration. Prompt how to
> launch under app?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/I-can-not-adjust-SearchRouter-Please-help-tp5295321p5298233.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20161201/73eb919b/attachment.html>
More information about the Mapbender_users
