[Mapbender-users] Mapbender 2.7.4: Customizing the display of WFS layers
lukas.bollack lukas.bollack at naturnetz.ch
Tue Feb 9 01:11:54 PST 2016
Hi Armin
Thanks for the explanation! I've tried and Mapbender uses the styling I
defined in Geoserver. Also, I've found out you can "style" the layers in
QGIS with it's graphical interface and then export the SLD definition into
Geoserver. I think this works perfectly for my project.
What I still don't understand: What's the function of the fields "Style"
"Buffer" and "Result Style" in the wfs-configuration window?
Also, if I add another field to a feature dataset in my postgis database for
which I already have a wfs-configuration: is there a way to tell mapbender
this field exists without loading the wfs again and creating a whole new
wfs-configuration?
Best Regards
Lukas
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapbender-2-7-4-Customizing-the-display-of-WFS-layers-tp5249094p5249637.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users mailing list
